Prestigio RoadRunner CUBE Full HD WiFi Sony Sensor Dashcam Black
£49.50
Delivery:
Standard: 1-3 working days
Key features
  • Full HD video
  • Built-in Wi-Fi
  • Overheating protection system
  • Type: Dashboard camera
  • Video Input: USB 2.0
  • Stock Status: In Stock
Product codes
Never worry about the quality of recorded video Full HD definition of Prestigio Roadrunner CUBE camera ensures that every single detail will be visible and you can be confident about your safety on the road. If an accident occurs you will get all the evidence of your innocence.
Product Description Prestigio Roadrunner CUBE - dashboard camera
Product Type Dashboard camera - 1080p - widescreen
Memory Card Slot SD card
Image Processor MSC8328P
Sensors G-sensor
Wireless Interface Wi-Fi
Sensor Resolution 2.0 MP
Effective Sensor Resolution Photo: 2.0 MP
Max Video Resolution 1920 x 1080
Lens System Wide-angle lens
Focus Adjustment Focus free
Display LCD display - 1.5"
Incident Detection G-Sensor
Supported Battery 1 x Li-Polymer rechargeable battery - 150 mAh (included)
Interface USB 2.0
Colour Black
Dimensions (WxDxH) 4.5 cm x 4.4 cm x 4.5 cm
Weight 72 g
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Prestigio RoadRunner C...
£49.50
