Q Acoustics M3 Soundbar - Bluetooth and Built-in Subwoofer
£229.00
Delivery:
  • Audio System Type: Soundbar
Product codes
Q Acoustics M3 Soundbar with Bluetooth and built-in subwoofer
  • From the most awarded soundbar designer Q Acoustics, designed to bring life to your TV sound
  • Beautifully styled, streamlined soundbar offers big TV and movie sound from a compact design
  • Sits on or in your TV unit or wall mount it with your TV
  • 180 degree sound speaker technology using BMR drivers for room-filling sound
  • Doubles up as a superb-sounding wireless music speaker - stream in superior aptX Bluetooth quality
  • Simple plug-and-play set-up with HDMI ARC input and Optical input
SIMPLICITY REDEFINED
The M3 is simplicity redefined where beautifully engineered sound meets beautiful design. M3 is an elegant, compact soundbar, designed to bring life to your living room without the clutter of a full Hi-Fi system.
The M3 is a true plug and play soundbar. Connect it to a television using an HDMI (ARC) input and it becomes one with the TV, Switch on the TV and the M3 automatically brings clarity of speech and a depth of soundscape that transforms the TV sound.
HEARING IS BELIEVING
It's hard to believe something so small delivers such a big, detailed sound. At Q Acoustics we have developed a streamlined acoustic offering that will allow you to discover previously unheard, subtle layers to your movie and music soundtracks through this compact soundbar.
Wide dispersion BMR drivers provide room-filling sound and clarity, whilst the inbuilt subwoofer gives a depth of soundscape that will transform your TV sound. The M3 boasts a MoviEQ control which has been designed to enhance movie sounds tracks, adding more bass; your home will rumble with powerful bass for that full blooded movie experience. To ensure the sound truly matches the picture up to 50ms of Lip Sync adjustment is available, adjustable in 10ms steps.
About Q Acoustics
- Q Acoustics is not like most other loudspeaker companies.
- Q Acoustics is a young brand. No heritage. No tradition. No old black and white photographs. We believe that is the secret of our success.
- Q Acoustics was established in 2006; not by a wealthy music lover, hobbyist designer or retired rock musician.
- Q Acoustics was founded by professional engineers and businessmen with the sole aim of developing a highly successful loudspeaker brand based on outstanding audio performance and being the best in class.
True Plug & Play Soundbar
With Q Acoustics' new Intelligent Pre-Amplifier (IPA) designed to seamlessly integrate into your home setup, the M3 is a true plug and play soundbar. Connect it into your home entertainment setup using Bluetooth aptX or the ARC HDMI input, and forget about it. For TV’s without HDMI ARC (Audio Return Channel) we recommend an Optical cable which will provide high quality audio.
Transform Your TV Sound
The M3 becomes one with your TV, leaving you to discover the two sides of this unique product, movie and music. Detailed and wide dispersion BMR's provide clarity, whilst the big heart, our inbuilt Dual Voice Coil (DVC) subwoofer, gives a depth of soundscape that will transform your TV sound.
Multi-award Winning Hi-Fi Brand
Q Acoustics is a multi-award winning hi-fi brand, which was founded by experts in the audio industry with the sole aim of developing a highly successful loudspeaker brand. It has been 10 years since Q Acoustics was founded, and in every year since we have continued to drive innovation and developed multi-award winning products.
What's in the box?
- 1 x QM3 Streamlined Bluetooth Soundbar
- 1 x Remote Control
- 1 x Lithium Battery, (3V, CR2025)
- 1 x HDMI Lead (2 metres)
- 1 x UK Mains Cable (Regional mains cable)
- 1 x Quick Start Guide
- 1 x Safety Warning Guide
- 1 x Wall Mounting Template
Beautifully Engineered Sound
- Frequency Response ±0.5dB : 20Hz – 20kHz
- S/N ratio (A-wtd): -85dB
- Mains Power: 100~240V – 50~60Hz – 100W
- Mid-High: BMR 58mm x 58mm
- Bass: DVC 100mm x 150mm
- Crossover: 340Hz
- System FQ Response +3/-6 dB : tbc
- Deep Standby: <0.5W
- Standby (Network Connected): <2.0W
Elegantly Streamlined
- Idle: 11.0W
- Optical DAC: 1 x 24-bit 48kHz Toslink
- Bluetooth: V4.0 Class II
- CODEC: aptX, AAC, MP3, SBC
- RCA Phono Maximum Sensitivity: 2.10Vrms
- 3.5mm Maximum Sensitivity: 1.10Vrms
- Height: 70mm
- Width: 1000mm
- Depth: 125mm
- Un-boxed Weight: 4.0kg
Powerful Dynamic Bass
- IPA
- MoviEQ
- NFC
- HDMI ARC
- CEC
- Bluetooth
- aptX
- AVRCP
- DAC: 24/48
- BMR
- DVC
- Dynamic Bass
Product Description Q Acoustics M3
Product Type Soundbar
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Q Acoustics M3 Soundba...
£229.00
