QNAP QSW-1208-8C 12 port Unmanaged Gigabit Ethernet Switch
£697.81
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Faster speeds using existing cables with 10GBASE-T & NBASE-T
  • Flexible deployment with eight combo ports
  • Near-silent and energy saving
  • Type: 10 Gigabit Ethernet
  • Ports: 12
  • Managed: No
  • POE: No
Product codes
The QNAP QSW-1208-8C is a 12-port 10GbE unmanaged switch, allowing you to instantly upgrade your network environment at a cost-effective price. The QSW-1208-8C supports 10GBASE-T and NBASE-T standards, allowing you to take advantage of higher network speeds with your existing Cat 5e and 6a cables. Both SFP+ (fiber) and RJ45 (copper) ports are available (with 8 combo ports) for servicing a range of network needs. Compliant with IEEE 802.3az (Energy Efficient Ethernet, EEE), the QSW-1208-8C is energy efficient as well. With high performance, low latency and superb functionality, the QSW-1208-8C is the ideal choice for upgrading your home or business network to support 10GbE connections.
Product Description QNAP QSW-1208-8C - switch - 12 ports - unmanaged - rack-mountable
Device Type Switch - 12 ports - unmanaged
Enclosure Type Rack-mountable
Subtype 10 Gigabit Ethernet
Ports 4 x 10 Gigabit SFP+ + 8 x combo 10 Gigabit SFP+
Performance Switching capacity: 240 Gbps
Capacity Priority queues: 8
MAC Address Table Size 27K entries
Jumbo Frame Support 9KB
Features Flow control, full duplex mode, Energy Efficient Ethernet, Class of Service (CoS)
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ae, IEEE 802.3an, IEEE 802.3aq, IEEE 802.3az, IEEE 802.3bz
Power AC 120/230 V (50 - 60 Hz)
Dimensions (WxDxH) 28.5 cm x 23.3 cm x 4.3 cm
Weight 2.15 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£697.81
