QNAP TS-453B-4G 4 Bay Desktop Enclosure
£602.72
16 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Extend NAS functionality with the PCIe Slot
  • QM2 expansion card rede?nes NAS function
  • OLED panel with capacitive touch buttons
  • Directly access files with USB-C QuickAccess
  • Data backup, recovery, and synchronization
  • Share and sync files across devices
  • QTS-Linux dual systems, geared for the IoT era
  • Datastore for virtualized environments
  • Storage for hosting virtual machines and containerized applications
  • Secure access with VPN & Proxy Server
  • QTS 4.3 - The most intelligent and intuitive NAS operating system
  • Qfiling automates your file organization
  • Capacity: 0GB
  • Interface: Ethernet, Fast Ethernet, Gigabit Ethernet
  • Stock Status: In Stock, Used Stock
Product codes
The QNAP TS-453B 4-Bay Network Attached NAS Storage device comes with a sleek new look, featuring an OLED panel and two capacitive touch buttons. With a USB Type-C QuickAccess port and a SD card slot, the QNAP TS-453B NAS simplifies transferring and sharing files without needing a network connection. The QNAP TS-453B NAS also provides feature-rich multimedia functionality, such as 4K video playback and real-time transcoding. The multi-zone multimedia management app Cinema28 and popular web automation app IFTTT Agent also enrich your multimedia experience and NAS automation.
  • Un-populated four (4) bay network attached NAS storage enclosure.
  • Powered by the latest 14 nm Intel Celeron J3455 quad-core 1.5GHz processor.
  • Supports QVR Pro (Beta) that integrates QNAP’s professional QVR system.
  • Features Intel AES-NI hardware-accelerated encryption to drive transfer speeds.
  • Supports 4K hardware decoding and transcodes 4K H.264 videos on-the-fly or offline.
  • Setup as a wireless access point by installing a compatible wireless network card.
  • Supports SMB, NFS and AFP to allow you to quickly share files to Windows and Mac.
  • Supports virtualization, centralised storage, backup, and disaster recovery.
  • USB QuickAccess port for direct access to files on NAS without needing a network connection.
  • iSCSI/ IP-SAN storage that supports VMware and Citrix, and compatible with Microsoft Hyper-V.
4GB RAM model
Product Description QNAP TS-453B - NAS server - 0 GB
Device Type NAS server
Host Connectivity Gigabit Ethernet
Total Storage Capacity 0 GB
Installed Devices / Modules Qty 0 (installed) / 4 (max)
Dimensions (WxDxH) 17 cm x 22.6 cm x 16.8 cm
Processor 1 x Intel Celeron J3455 1.5 GHz (Quad-Core)
Storage Controller RAID SATA 6Gb/s
Networking 10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported 40
RAM 4 GB
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: D3C3 041751
£439.16
product
Ref: D3C3 041751
Accessories
Packaging
Functional
Software
Manuals
£439.16
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
QNAP TS-453B-4G 4 Bay...
£602.72
