The QNAP TS-453B 4-Bay Network Attached NAS Storage device comes with a sleek new look, featuring an OLED panel and two capacitive touch buttons. With a USB Type-C QuickAccess port and a SD card slot, the QNAP TS-453B NAS simplifies transferring and sharing files without needing a network connection. The QNAP TS-453B NAS also provides feature-rich multimedia functionality, such as 4K video playback and real-time transcoding. The multi-zone multimedia management app Cinema28 and popular web automation app IFTTT Agent also enrich your multimedia experience and NAS automation.
4GB RAM model
Product Description | QNAP TS-453B - NAS server - 0 GB | Device Type | NAS server | Host Connectivity | Gigabit Ethernet | Total Storage Capacity | 0 GB | Installed Devices / Modules Qty | 0 (installed) / 4 (max) | Dimensions (WxDxH) | 17 cm x 22.6 cm x 16.8 cm | Processor | 1 x Intel Celeron J3455 1.5 GHz (Quad-Core) | Storage Controller | RAID SATA 6Gb/s | Networking | 10Mb LAN, 100Mb LAN, GigE | IP Cameras Supported | 40 | RAM | 4 GB |
General | |
Width | 17 cm |
Depth | 22.6 cm |
Height | 16.8 cm |
Built-in Devices | OLED display |
Processor / Memory | |
Processors Installed | 1 x Intel Celeron J3455 1.5 GHz |
Number of Cores | Quad-Core |
Max Supported Qty | 1 |
Max Turbo Speed | 2.3 GHz |
RAM | 4 GB (installed) / 8 GB (supported) - DDR3L |
Storage Controller | |
Type | RAID |
Interface Type | SATA 6Gb/s |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, GigE |
Encryption Algorithm | AES-NI |
Security DVR | |
Expansion / Connectivity | |
Expansion Bays | 4 (total) / 4 (free) x hot-swap - 2.5" / 3.5" |
Expansion Slots | 2 (total) / 0 (free) x SO-DIMM 204-pin , X PCI Express |
Interfaces | 2 x Ethernet 1000Base-T - RJ-45 , 5 x USB 3.0 , 2 x microphone - mini-jack , 2 x HDMI output , 1 x audio out |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Remote control |
Power | |
Power Device | External power adapter |
