QNAP TS-832XU-RP-4GB 8 Bay Rackmount NAS
£1,187.90
Delivery:
Key features
  • The built-in 10GbE SFP+ ports deliver high speed for mission-critical applications such as database hosting and VM storage
  • One PCIe 2.0 ×2 slot (×4 length) is available for adding a 10GbE port and/or M.2 SSD slots. With SSDs installed, Qtier auto tiering can be enabled to optimize storage utilization
  • Snapshots add an extra layer of protection to your disaster recovery plan, giving you the flexibility to create and revert snapshots locally and/or remotely
  • The Hybrid Backup Sync app completes your backup strategies, allowing you to back up, restore and sync files locally and remotely
  • QNAP's Virtual JBOD technology can be used to expand remote NAS capacity, ensuring all available space can be fully utilized
  • The hot-swappable redundant power supply ensures high reliability and maximum system uptime
  • Capacity: 0GB
  • Interface: 10 Gigabit Ethernet, Ethernet, Fast Ethernet, Gigabit Ethernet
  • Type: 8-Bay
Product codes
The TS-832XU-RP is built to deliver high performance, flexible expansion capabilities and versatile applications at an affordable and cost-effective price for small/medium-sized businesses. Two 10GbE SFP+ ports are capable of high-speed transmission of time-critical business data and a PCI Express (PCIe) 2.0 ×2 slot (×4 length) provides flexibility for expanding connectivity and/or storage with M.2 SATA/PCIe NVMe SSDs, via QNAP's QM2 expansion cards. The TS-832XU-RP can be deployed to suit various needs for data storage, file backup, disaster recovery, containerized applications, surveillance, and more. The TS-832XU-RP is also equipped with a redundant power supply to ensure uninterrupted services.
Product Description QNAP TS-832XU-RP - NAS server - 0 GB
Device Type NAS server
Host Connectivity Gigabit Ethernet / 10 Gigabit Ethernet
Enclosure Type Rack-mountable - 2U
Total Storage Capacity 0 GB
Installed Devices / Modules Qty 0 (installed) / 8 (max)
Dimensions (WxDxH) 48.2 cm x 53.4 cm x 8.9 cm
Processor 1 x Annapurna Labs Alpine AL-324 1.7 GHz (Quad-Core)
Storage Controller RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, 50, JBOD, 5 hot spare, 6 hot spare, 60, 50 hot spare, 10 hot spare, 60 hot spare
Networking 10Mb LAN, 100Mb LAN, GigE, 10 GigE
RAM 4 GB
Power AC 120/230 V (50/60 Hz)
Power Redundancy Yes
Storage Operating System QNAP QTS 4.3.4
System Requirements UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10, Microsoft Windows Server 2016
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
QNAP TS-832XU-RP-4GB 8...
£1,187.90
