QNAP TS-873-4G/64TB-RED 8 Bay NAS
£2,993.80
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Dual M.2 SATA 6 Gb/s SSD slots allow for setting up caching or storage pools, improving file access efficiency
  • Qtier auto-tiering technology and SSD caching enable 24/7 optimized storage efficiency
  • Scalable storage supporting virtualization, containerized apps, centralized storage, backup, sharing, and disaster recovery
  • Snapshots fully record system status and data
  • If files are accidentally deleted or modified, you can quickly restore the data from a snapshot
Product codes
The TS-873 is powered by a high-performance and energy-efficient CPU and provides two PCIe slots for greater functionality. You can install a QNAP QM2 expansion card to add M.2 SSD caching/10GbE connectivity; a compatible wireless card to use the TS-873 as a wireless access point; and an entry-level graphics card to boost system performance for 4K video performance. The TS-873 allows you to flexibly deploy a wide range of applications with a more affordable budget.
QNAP TS-873-4G - NAS server - 0 GB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
0 (installed) / 8 (max)
32.93 cm x 27.96 cm x 18.82 cm
6.59 kg
1 x AMD R-series RX-421ND 2.1 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare
10Mb LAN, 100Mb LAN, GigE
RAM
4 GB
Storage Operating System
QNAP QTS 4.3.4
UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
QNAP TS-873-4G/64TB-RE...
£2,993.80
