QNAP TVS-882BR-ODD-i5-16G 8 Bay NAS Desktop
Key features
  • Two M.2 SATA 6 Gb/s slots and Qtier auto-tiring for optimized storage efficiency
  • Triple HDMI output enables direct disc playing through virtual machines
  • Qfiling enables automatic file organization; Qsirch full-text search helps locate files faster
  • Supports QRM+ unified remote server management, QvPC technology, virtual machine and container applications, and storage for virtualization
Product codes
The TVS-882BR uses advanced processors, providing advanced hardware with enhanced tiring storage, application-based partitioning and network traffic distribution. The TVS-882BR comes with a SATA optical disc drive (ODD) slot, allowing you to install a compatible Blu-ray Disc drive. QNAP also provides models with a preloaded ODD, allowing you to experience extensive disc applications right way. With simple installation, you can backup the content of your discs to NAS for long-term storage and easier sharing, or you can burn NAS files to disc.
Product Description QNAP TVS-882BR - NAS server - 0 GB
Device Type NAS server
Host Connectivity Gigabit Ethernet
Total Storage Capacity 0 GB
Installed Devices / Modules Qty 0 (installed) / 8 (max)
Dimensions (WxDxH) 36.99 cm x 31.98 cm x 23.46 cm
Weight 12.18 kg
Processor 1 x Intel Core i5 7500 3.4 GHz (Quad-Core)
Storage Controller RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD
Optical Storage 1 x BD-Writer
Networking 10Mb LAN, 100Mb LAN, GigE
RAM 16 GB
Power AC 120/230 V (50/60 Hz)
Storage Operating System QNAP QTS 4.2
System Requirements UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
QNAP TVS-882BR-ODD-i5-...
