QNAP VS-12140U-RP-Pro+ 40 Channel 12 Bay 2U Rackmount NVR
Key features
  • Megapixel recordings
  • Multi-stream support
  • Smart recording
  • Real-time digital watermarking
  • High resolution local display
  • Convenient control of PTZ and speed dome cameras
  • Digital zoom
  • On-screen event alert
  • Video search
  • Local video playbacks on HDMI monitors or TVs
  • Quick system setup
  • Cross-browser compatibility
  • Smart control of PTZ and speed dome cameras
  • Preset position control and auto cruising
  • Instant event notification
  • Digital zoom
  • Dynamic E-map
  • Multi-view playback
  • Video search by date and time, timeline, event, intelligent video analytics
  • Storage expansion
  • Scheduled remote replication
  • Intel CPU and DDRIII memory for superior system performance
  • Linux embedded system
  • Huge storage capacity for long-term recordings
  • Fisheye dewarping
  • Authority management
  • Auto logoff
  • Host access control
  • Advanced RAID with hot-swap design
  • S.M.A.R.T. and advanced HDD Health Scanning (HHS)
  • Automatic system startup after power recovery
  • System setup in simple steps
  • Web-based user interface
  • Smart search of IP cameras for quick settings
Product codes
The QNAP VS-12140U-RP Pro+ VioStor NVR (Network Video Recorder) is the high-end 2U chassis network surveillance server which supports high quality real-time video/audio monitoring, megapixel recording (up to 10-megapixel), and playback of multiple IP cameras. The VioStor VS-12140U-RP Pro+ can simultaneously handle inputs from up to 40-megapixel cameras. Featuring a powerful quad-core Intel Core i5 processor and DDR3 memory, this enterprise-grade NVR delivers high performance with throughput of 450 Mbps for recording and smooth playback of multiple megapixel cameras. Moreover, the HDMI output and hardware decoder of VS-12140U-RP Pro+ provide the ability to deliver up to 300fps Full HD local display.
The VioStor VS-12140U-RP Pro+ supports large storage capacity, which makes it proficient for continuous recording of high-resolution video.
The Linux-based VioStor VS-12140U-RP Pro+ enables quick and easy deployment of multiple NVRs. It is designed with the user in mind, offering simple and intuitive setup in six steps. Coupled with powerful performance and stability, this solution is tailor-made for enterprise surveillance needs.
QNAP VioStor VS-12140U-RP Pro+ - standalone NVR - 40 channels
NVR - 40 channels - networked - rack-mountable - 2U
IP Cameras Supported
40
Frame Rate
30 fps
Compression Format
MJPEG, MPEG-4, H.264, MxPEG
Hard Drive(s) Supported
Quantity: 12 - total capacity: 48 TB
Voltage
120 / 230 V
43.9 cm x 52 cm x 8.8 cm
15.88 kg
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
QNAP VS-12140U-RP-Pro+...
