QNAP VS-12148U-RP-Pro+ 48 Channel 12 Bay 2U Rackmount NVR
Key features
  • Megapixel recordings
  • Multi-stream support
  • Smart recording
  • Real-time digital watermarking
  • High resolution local display
  • Convenient control of PTZ and speed dome cameras
  • Video search
  • Local video playbacks on HDMI monitors or TVs
  • Quick system setup
  • Instant event notification
  • Digital zoom
  • Dynamic E-map
  • Multi-view playback
  • Fisheye dewarping
  • Authority management
  • Auto logoff
  • Host access control
  • Detailed event logs
  • Web-based user interface
  • Smart search of IP cameras for quick settings
Product codes
The QNAP VS-12148U-RP Pro+ VioStor NVR (Network Video Recorder) is the high-end 2U chassis network surveillance server which supports high quality real-time video/audio monitoring, megapixel recording, and playback of multiple IP cameras. The VioStor VS-12148U-RP Pro+ can simultaneously handle inputs from up to 48-megapixel cameras. Featuring a powerful Quad-core Intel Core i5 processor and DDR3 memory, this enterprise-grade NVR delivers high performance with throughput of 450 Mbps for recording and smooth playback of multiple megapixel cameras. Moreover, the HDMI output and hardware decoder of VS-12148U-RP Pro+ provide the ability to deliver up to 300 fps Full HD local display.
The Linux-based VioStor VS-12148U-RP Pro+ enables quick and easy deployment of multiple NVRs. It is designed with the user in mind, offering simple and intuitive setup in six steps. Coupled with powerful performance and stability, this solution is tailor-made for enterprise surveillance needs.
QNAP VioStor VS-12148U-RP Pro+ - standalone NVR - 48 channels
NVR - 48 channels - networked - rack-mountable - 2U
IP Cameras Supported
48
Frame Rate
30 fps
Compression Format
MJPEG, MPEG-4, H.264, MxPEG
Hard Drive(s) Supported
Quantity: 12 - total capacity: 48 TB
Voltage
120 / 230 V
43.9 cm x 52 cm x 8.8 cm
15.88 kg
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
QNAP VS-12148U-RP-Pro+...
