QNAP VS-2108 PRO+ 8 Channel 2 Bay Tower NVR
Key features
  • High resolution local display
  • Convenient control of PTZ and speed dome cameras
  • Digital zoom
  • On-screen event alert
  • Local video playbacks on HDMI monitors or TVs
  • Quick system setup
  • Preset position control and auto cruising
  • Instant event notifications
  • Dynamic E-map
  • Multi-view playback
  • Advanced event management
  • Real-time SMS and email alert
  • Scheduled remote replication
  • One touch auto video backup
  • CPU thermal solution with fan-less design
  • Linux embedded system
  • Touch-N-Go PC-less installation
  • Mobile surveillance by VMobile
  • Fisheye dewarping
  • Host access control
  • Advanced RAID with hot-swap design
  • Automatic system startup after power recovery
  • DOM architecture with embedded fail-safe Dual OS for enhanced reliability
Product codes
Powered by the Intel dual-core processor and 4 GB of memory, it delivers high performance at a throughput rate of 180 Mbps to ensure stable recordings and smooth playbacks of multiple megapixel cameras. The 2-bay VS-2108 Pro+ is designed for the SMB and small-office/home office segment with the features of robust performance, solid reliability and high-definition local display.
The VS-2108 Pro+ can support up to 8TB of storage capacity, with 4TB on each hard drive respectively, to accommodate high quality H. 264, MPEG-4, M-JPEG, and MxPEG recording videos. The server-grade mainboard and heat pipe with fanless design assure the solid reliability for maximized system uptime. Moreover, the VS-2108 Pro+ supports local display via an HDMI cable, with up to 180 fps Full HD 1080p local display by hardware decoding.
QNAP VioStor VS-2108 Pro+ NVR - standalone NVR - 8 channels
NVR - 8 channels - networked
IP Cameras Supported
8
Compression Format
MJPEG, MPEG-4, H.264
Image Resolution
1920x1080
Hard Drive(s) Supported
Quantity: 2
Voltage
100 - 240 V
10.2 cm x 21.8 cm x 15.4 cm
2.5 kg
Country Kits
United Kingdom
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
QNAP VS-2108 PRO+ 8 Ch...
