QNAP VS-4112U-RP-Pro+ 12 Channel 4 Bay 1U Rackmount NVR NAS
Key features
  • Megapixel recordings
  • Multi-stream support
  • Smart recording
  • Real-time digital watermarking
  • High resolution local display
  • Convenient control of PTZ and speed dome cameras
  • Digital zoom
  • On-screen event alert
  • Video search
  • Local video playbacks on HDMI monitors or TVs
  • Quick system setup
  • Cross-browser compatibility
  • Smart control of PTZ and speed dome cameras
  • Preset position control and auto cruising
  • Instant event notification
  • Digital zoom
  • Dynamic E-map
  • Multi-view playback
  • Video search by date and time, timeline, event, intelligent video analytics
  • Storage expansion
  • Scheduled remote replication
  • Intel CPU and DDRIII memory for superior system performance
  • Linux embedded system
  • Huge storage capacity for long-term recordings
  • Fisheye dewarping
  • Authority management
  • Auto logoff
  • Host access control
  • Advanced RAID with hot-swap design
  • S.M.A.R.T. and advanced HDD Health Scanning (HHS)
  • Automatic system startup after power recovery
  • System setup in simple steps
  • Web-based user interface
  • Smart search of IP cameras for quick settings
Product codes
Powered by the Intel dual-core processor and large capacity memory, it delivers high performance at a throughput rate of 250 Mbps to ensure stable recordings and smooth playbacks of multiple megapixel cameras. The 4-bay rackmount VS-4112U-RP Pro+ is designed for the SMB segment with the features of robust performance, solid reliability and high-definition local display.
The VS-4112U-RP Pro+ can support large storage capacity, with hard drive respectively, to accommodate high quality H.264, MPEG-4, M-JPEG, and MxPEG recording videos. The VS-4112U-RP Pro+ supports local display via an HDMI cable, with up to 180 fps Full HD 1080p local display by hardware decoding.
Product Description QNAP VioStor VS-4112U-RP Pro+ - standalone NVR - 12 channels
Device Type NVR - 12 channels - networked - rack-mountable - 1U
IP Cameras Supported 12
Frame Rate 30 fps
Compression Format MJPEG, MPEG-4, H.264, MxPEG
Hard Drive(s) Supported Quantity: 4 - total capacity: 16 TB
Voltage 120 / 230 V
Dimensions (WxDxH) 43.9 cm x 49.9 cm x 4.4 cm
Weight 11.54 kg
Country Kits Europe
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
QNAP VS-4112U-RP-Pro+...
