QNAP VS-4116U-RP-Pro+ 16 Channel 4 Bay 1U Rackmount NVR NAS
Key features
  • Multi-stream support
  • Smart recording
  • Real-time digital watermarking
  • High resolution local display
  • Convenient control of PTZ and speed dome cameras
  • Digital zoom
  • On-screen event alert
  • Local video playbacks on HDMI monitors or TVs
  • Quick system setup
  • Multi-server monitoring
  • Smart control of PTZ and speed dome cameras
  • Preset position control and auto cruising
  • Instant event notification
  • Dynamic E-map
  • Multi-view playback
  • Video search by date and time, timeline, event, Intelligent Video Analytics (IVA)
  • Advanced event management
  • Real-time SMS and email alert
  • Scheduled remote replication
  • One touch auto video backup
  • Huge storage capacity for long-term recordings
  • Fisheye dewarping
  • Authority management
  • Auto logoff
  • Host access control
  • On-line user list
  • Detailed event logs
  • S.M.A.R.T. and advanced HDD Health Scanning (HHS)
  • Automatic system startup after power recovery
  • Built-in DDNS service
  • Built-in NTP server
  • System setup in simple steps
  • Web-based user interface
Product codes
Powered by the Intel dual-core processor, it delivers high performance at a throughput rate of 250 Mbps to ensure stable recordings and smooth playbacks of multiple megapixel cameras. The 4-bay rackmount VS-4116U-RP Pro+ is designed for the SMB segment with the features of robust performance, solid reliability and high-definition local display. The VS-4116U-RP Pro+ supports local display via an HDMI cable, with up to 180 fps Full HD 1080p local display by hardware decoding.
QNAP VioStor VS-4116U-RP Pro+ - standalone NVR - 16 channels
NVR - 16 channels - networked - rack-mountable - 1U
IP Cameras Supported
16
Frame Rate
30 fps
Compression Format
MJPEG, MPEG-4, H.264, MxPEG
Hard Drive(s) Supported
Quantity: 4 - total capacity: 16 TB
Voltage
120 / 230 V
43.9 cm x 49.9 cm x 4.4 cm
Country Kits
United Kingdom
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
QNAP VS-4116U-RP-Pro+...
