QNAP VS-6112 Pro+ 12 Channel 6 Bay Desktop NVR NAS
Key features
  • Megapixel recordings
  • Real-time digital watermarking
  • High resolution local display
  • Convenient control of PTZ and speed dome cameras
  • Digital zoom
  • On-screen event alert
  • Multi-server monitoring
  • Smart Control of PTZ & Speed Dome Cameras
  • Preset position control and auto cruising
  • Instant event notification
  • Multi-view playback
  • Scheduled remote replication
  • One touch auto video backup
  • Intel CPU and DDRIII memory for superior system performance
  • CPU thermal solution with fan-less design
  • S.M.A.R.T. & advanced HDD Health Scanning (HHS)
Product codes
Powered by the Intel dual-core processor and large memory, it delivers high performance at a throughput rate of 330 Mbps to ensure stable recordings and smooth playbacks of multiple megapixel cameras. The 6-bay VS-6112 Pro+ is designed for the SMB segment with the features of robust performance, solid reliability and high-definition local display.
The VS-6112 Pro+ can support large storage capacity, with 4 TB on each hard drive respectively, to accommodate high quality H.264, MPEG-4, M-JPEG, and MxPEG recording videos. The server-grade mainboard, Sanyo Denki system fan, and heat pipe with fanless design assure the solid reliability for maximized system uptime. Moreover, the VS-6112 Pro+ supports local display via an HDMI cable, with up to 180 fps Full HD 1080p local display by hardware decoding.
QNAP VioStor VS-6112 Pro+ NVR - standalone NVR - 12 channels
NVR - 12 channels - networked
IP Cameras Supported
12
Frame Rate
30 fps
Compression Format
MJPEG, MPEG-4, H.264
Image Resolution
1920x1080
Hard Drive(s) Supported
Quantity: 6
Voltage
100 - 240 V
26 cm x 23.5 cm x 18.5 cm
5.7 kg
Country Kits
United Kingdom
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
QNAP VS-6112 Pro+ 12 C...
