When it comes to the competition, it's time to make a killer statement. Deliver deadly performance and show no mercy with best-in-class ergonomics combined with next-generation sensor and switches.
Product Description | Razer DeathAdder V2 - mouse - USB | Device Type | Mouse - ergonomic | Connectivity Technology | Wired - USB | Orientation | Right-handed | Dimensions (WxDxH) | 6.17 cm x 12.7 cm x 4.27 cm | Weight | 82 g | Movement Detection Technology | Optical | Buttons Qty | 8 | Movement Resolution | 20000 dpi | Performance | 50 G maximum acceleration, realtime sensitivity switching 400/800/1600/2400/3200 dpi, 70 million clicks, 650 inches per second | Features | Programmable buttons, scrolling wheel, RGB 16.8 millions multi-colour illumination, Razer Synapse 3 enabled | Cable Length | 2.1 m | Manufacturer Warranty | 2-year warranty |
General | |
Device Type | Mouse |
Ergonomic Design | Yes |
Width | 6.17 cm |
Depth | 12.7 cm |
Height | 4.27 cm |
Weight | 82 g |
Input Device | |
Connectivity Technology | Wired |
Interface | USB |
Buttons Qty | 8 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
