Razer Hammerhead True Wireless x
FREE DELIVERY
£59.98
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 60 ms low latency Gaming Mode
  • Mobile app customization
  • Custom-tuned 13 mm drivers
  • Recommended Use: Portable electronics
  • Connectivity: Wireless
Product codes
The Razer Hammerhead in-ear headphones are in-ear monitors (IEM) engineered from the ground up to set the standard in portable gaming audio. Machined out of aircraft grade aluminum, the Razer Hammerhead embodies ultimate durability packaged in a lightweight, comfortable form factor.
Encased within each sleek, brushed shell is a high performance, precision-tuned 9 mm neodymium driver. Paired with an optimized inner acoustics chamber in each shell, these in-ear monitors produce a sound signature that packs a mean, earth-shattering bass while maintaining crystal clear mids and highs. The Razer Hammerhead comes through with a full-bodied low-end frequency, pounding in the beats without distortion. The Razer Hammerhead epitomizes the way in-ear monitors should be experienced - with style, comfort and aural fidelity.
LIGHT IT UP
Light it up with the Razer Hammerhead True Wireless X—high-performance earbuds engineered to illuminate. Packing a 60ms low latency Gaming Mode along with custom-tuned 13mm drivers, brace yourself for audio that rises above the noise.
60MS LOW LATENCY GAMING MODE
Activate Gaming Mode to fire up the Razer Hammerhead True Wireless X’s leading performance while gaming on Bluetooth devices for a more seamless and lag-free experience
MOBILE APP CUSTOMIZATION
Maximize your earbuds with the Razer Audio app. Remap touch gestures, customize the EQ, and get continuous improvements with over-the-air firmware updates
WATER RESISTANT DESIGN
Because the earbuds are water-resistant, you can work out to your favorite tunes and have the freedom to wear them in a variety of outdoor activities
BLUETOOTH 5.2 WITH AUTO-PAIRING
Endowed with the increased bandwidth, range, and energy efficiency of Bluetooth 5.2, the earbuds last longer and automatically connect to their last paired device for easy handling.
GOOGLE FAST PAIR
During initial setup, conveniently pair your Razer Hammerhead True Wireless X with Bluetooth capable Android devices with a single tap of a pop-up notification
TOUCH-ENABLED CONTROLS
Control your music and calls, enable Gaming Mode, and activate your smartphone’s voice assistant—all with a few easy taps.
QUICK SPECS
• 60ms low latency Gaming Mode
• Custom-tuned 13mm drivers
• Bluetooth 5.2 with Auto-Pairing
• Google Fast Pair
• Touch-enabled controls
Product Description Razer Hammerhead True Wireless X - true wireless earphones with mic
Product Type True wireless earphones - Bluetooth
Recommended Use Portable electronics
Additional Functions LED backlight (green)
Headphones Form Factor In-ear
Wireless Technology Bluetooth
Bluetooth Version Bluetooth 5.2
Sound Output Mode Stereo
Audio Specifications Frequency Response 20 - 20000 Hz - Sensitivity 91 dB/mW
Impedance 32 Ohm
Max Input Power 8 mW
Microphone Operation Mode Omni-directional
Manufacturer Warranty 2 Years
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£59.98
