Next generation Xbox mobile gaming
The Kaira Pro is specifically designed for multi-device compatibility, capable of connecting to a variety of platforms and devices. Using Xbox Wireless and Bluetooth 5.0, the Kaira Pro can be connected to the new Xbox Series X|S without the need for a dongle, and to Windows 10 PC and Android phones or tablets via Bluetooth 5.0, allowing gamers to take their headset to as many places as they take their games.
Using an innovative dual microphone design, the Kaira Pro has a detachable Razer HyperClear Supercardioid Mic for crystal-clear voice chat. When out and about, the microphone can be removed, and a separate, built-in mobile microphone, concealed within the headset automatically takes over voice communication, keeping the look of the Kaira Pro clean and lightweight.
Highest comfort on the couch and on the go
Designed for long play sessions, the Kaira Pro uses an ultra-soft breathable memory foam, with ear cushions designed to minimize heat build-up and perspiration. A soft, well-padded headband over a lightweight stainless-steel frame ensures a flexible and extremely durable design. The Kaira Pro Designed for Xbox is the ultimate audio solution for next-gen Xbox gaming. No matter if you play your favorite games on Xbox Series X|S or prefer to play on Android devices via cloud gaming with Xbox Game Pass Ultimate, the Kaira Pro delivers a high-quality sound experience and crystal-clear chat communication in any situation.
CONSOLE. MOBILE. COMBINED
Enjoy cutting-edge audio performance that embraces the future of Xbox. Enter the Razer Kaira Pro—a wireless headset for Xbox Series X|S and mobile gaming. Fitted with our best drivers and headset mic, experience stellar sound and voice chat for unrivalled console and mobile gaming.
XBOX WIRELESS AND BLUETOOTH 5.0
The Razer Kaira Pro for Xbox is designed for two modes of gaming.
FOR XBOX SERIES X|S
Direct, low-latency console gaming via Xbox Wireless.
FOR MOBILE DEVICES
Seamless, convenient mobile gaming via Bluetooth 5.0—optimized for Xbox Game Pass.
RAZER™ TRIFORCE TITANIUM 50MM DRIVERS
Our all-new patented design allows our engineers to custom tune each driver as though there are three—allowing for the individual replications of high, mid and low audio frequencies to deliver richer trebles, brighter sound and powerful bass. This Xbox Series X|S wireless headset also includes titanium-coated diaphragms, giving added clarity to any vocals you hear so that any comms you receive is always crisp and clear.
RAZER™ HYPERCLEAR SUPERCARDIOID MIC
The pickup pattern on this detachable 9.9mm mic has more noise rejection from the sides as compared to a cardioid mic, and provides a true recreation of your voice thanks to a sensitive low frequency response and an open microphone housing designed for minimal obstruction.
FLOWKNIT MEMORY FOAM EAR CUSHIONS
To keep you in peak form during gaming marathons, our new breathable weave minimizes sweat and heat build-up generated by skin contact, while the ultra-soft foam’s improved density greatly reduces the headset’s clamping force.
DEDICATED MOBILE MIC
Hidden in this Xbox Series X|S wireless headset is a second mic that works without the Razer™ HyperClear Supercardioid Mic—handy for when you need to talk while commuting, whether it’s for mobile gaming or answering calls.
EQ TOGGLE AND XBOX PAIRING BUTTON
Located on the right earcup, hold down the button to pair your headset easily, and press it twice to cycle through 4 EQ settings—such as FPS Mode that enhances in-game audio like enemy footsteps, and Bass Mode to amplify low frequency sounds.
WINDOWS SONIC
Experience lifelike surround sound that allows the headset to place audio with pinpoint accuracy, heightening your in-game awareness for a competitive edge and truly immersive experience.
ADVANCED APP CONFIGURATION
Supported by the Razer™ Headset Setup for Xbox app, get it sounding exactly the way you want with access to deeper audio customization options such as personal EQ presets, mic monitoring, and more.
Got an old games console lying around?
When you trade in your old device at BT you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Razer Kaira Pro for Xbox - headset | Product Type | Headset - Bluetooth / Xbox Wireless - wireless | Recommended Use | Game console, portable electronics | Colour | White | Image Colour Disclaimer | The displayed product image may be a different colour | Headphones Form Factor | Full size | Connectivity Technology | Wireless | Wireless Technology | Bluetooth / Xbox Wireless | Bluetooth Version | Bluetooth 5.0 | Sound Output Mode | Stereo | Sound Effects | Windows Sonic surround sound | Audio Specifications | Frequency Response 20 - 20000 Hz - Sensitivity 108 dB | Impedance | 32 Ohm | Noise Isolating | Noise isolating | Microphone | Boom | Microphone Operation Mode | Super cardioid | Microphones Included | 2 | Controls | Volume, power on/off, microphone on/mute switch, status indicator, pair mode, equaliser preset, game/chat balance | Manufacturer Warranty | 2-year warranty | Designed For | Xbox Series S, Xbox Series X |
General | |
Weight | 330 g |
Colour | White |
Earpad Material | FlowKnit memory foam |
Features | Xbox Wireless technology |
Max Operating Distance | 10 m |
Audio Output | |
Noise Isolating | Yes |
Frequency Response | 20 - 20000 Hz |
Sensitivity | 108 dB |
Diaphragm | 50 mm |
Magnet Material | Razer Triforce titanium |
Adjustable Headband | Yes |
Features | RGB illumination |
Microphone | |
Type | Boom |
Form Factor | Detachable headset microphone |
Sensitivity | -54 dB |
Sensitivity Margin | +/- 3dB |
Frequency Response | 100 - 10000 Hz |
Remote Control | |
Power | |
Battery | Headphone battery rechargeable |
Run Time (Up To) | 20 hour(s) |
Run Time Details | Continuous talk (with LED lights): up to 15 hours , Continuous talk: up to 20 hours |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Compatibility Information | |
