Razer Kiyo Pro
FREE DELIVERY
Razer Kiyo Pro
£179.00
Delivery:
Standard: 1-3 working days
Key features
  • High-performance adaptive light sensor
  • Uncompressed 1080p 60FPS
  • HDR-enabled
  • Type: Streaming Camera
  • Stock Status: In Stock
Product codes
Achieve professional video standards for streaming and video conferencing with the Razer Kiyo Pro - an FHD USB webcam that has a high-performance adaptive light sensor, so you can enjoy crisp, clear quality in any setup and lighting condition.
ADVANCED IMAGING. ABSOLUTE FIDELITY
Achieve the highest standards of streaming with the Razer Kiyo Pro—a USB webcam with a high-performance adaptive light sensor for max fidelity at 1080p 60FPS, and the ability to enable HDR at 30FPS. Give your viewers the pro-grade clarity and quality they deserve in any setup and lighting condition.
HIGH-PERFORMANCE ADAPTIVE LIGHT SENSOR
The webcam is driven by a larger Type 1/2.8 ultra-sensitive CMOS sensor with STARVIS™* technology that adapts to any lighting condition, ensuring picture-perfect clarity for any setup.
UNCOMPRESSED 1080P 60FPS
With the highest fidelity that comes with uncompressed Full HD 1080p 60FPS video, your stream will be more engaging and natural to watch with smooth, lifelike quality.
HDR-ENABLED
Make your stream pop with a full spectrum of vibrant colors by activating HDR at 30FPS, which ramps up your video’s dynamic range while correcting over and underexposed areas.
WIDE-ANGLE LENS WITH ADJUSTABLE FOV
Find the right amount of visual space you need to display your showmanship, with a large aperture, wide-angle lens that allows for three field-of-view options selectable via Razer Synapse.
LIGHTNING-FAST USB 3.0
With its plug-and-play USB 3.0 connection, the Razer Kiyo Pro delivers a powerful 5GB/s camera signal to your stream, allowing for maximized video performance with no compression whatsoever.
FLEXIBLE MOUNTING OPTIONS
The stable webcam mount sits snugly on your monitor and can be tilted up or down to find the perfect angle, but can also be detached if you prefer the webcam to be on a tripod setup.
Product Description Razer Kiyo Pro - webcam
Device Type Webcam
Audio Yes: built-in microphone
Connectivity Technology Wired
Camera Colour
Max Resolution 1920 x 1080
Frame Rate (max) 60 frames per second
Video Modes 480p, 720p, 1080p, 360/30p
Optical Sensor Type 2.1 MP
Focus Adjustment Automatic
Interfaces USB 3.0
Cables Included SuperSpeed USB cable - 1.5 m
Features High Dynamic Range (HDR), privacy shutter, STARVIS sensor, Corning Gorilla Glass 3
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Razer Kiyo Pro
£179.00
