We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The construction of the Razer Kraken had a singular motivation - durability to withstand daily abuse on the go, whether they are tuning out your daily commute or providing the soundtrack while you hit the slopes. Their light-weight design makes these headphones comfortable for hours on end.
The ear cups of the Razer Kraken are foldable, making the footprint of these full-sized headphones extremely compact for maximum mobility so you can take them along anywhere you go.
The Razer Kraken is outfitted with large 40mm neodymium magnet drivers tuned for crystal clear music in the high-and mid-ranges and packing deep bass for powerful lows, making them versatile music and gaming headphones.
Got an old games console lying around?
When you trade in your old device at BT you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Razer Kraken Kitty - headset | Product Type | Headset - wired - USB | Compatibility | Mac, Windows | Recommended Use | Game console, computer | Colour | Quartz pink | Headphones Form Factor | Full size | Connectivity Technology | Wired | Sound Output Mode | Stereo | Sound Effects | 7.1 Channel Virtual Surround Sound, THX Spatial Audio | Audio Specifications | Frequency Response 20 - 20000 Hz - Sensitivity 109 dB | Impedance | 32 Ohm | Noise Isolating | Noise isolating | Microphone | Boom | Microphone Operation Mode | Uni-directional | Microphone Noise Cancelling | Yes | Controls | Mute, volume | Manufacturer Warranty | 2-year warranty |
General | |
Width | 17.2 cm |
Depth | 9.8 cm |
Height | 19.3 cm |
Weight | 408 g |
Headband Material | Metal |
Earpad Material | Memory foam |
Audio Output | |
Noise Isolating | Yes |
Frequency Response | 20 - 20000 Hz |
Sensitivity | 109 dB |
Diaphragm | 50 mm |
Magnet Material | Neodymium magnet |
Adjustable Headband | Yes |
Features | Razer Chroma lighting |
Microphone | |
Type | Boom |
Sensitivity | -45 dB |
Frequency Response | 100 - 10000 Hz |
Signal-To-Noise Ratio | 60 dB |
Remote Control | |
Connections | |
Connector Type | Headset (USB) |
Cable | |
Cable Length | 2 m |
Miscellaneous | |
Cable Details | Headset cable - 2 m |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 2 years |
