Experience pure, high-fidelity sound with zero distractions for all your entertainment wherever you go. Tested and optimized by experts in cinematic audio immersion at THX Ltd., the headset presents a rich, balanced soundstage for all your movies, music and gaming.
Bluetooth 5.0 connectivity
FORGET THE NOISE
Introducing wireless THX® Certified Headphones equipped with advanced active noise cancellation (ANC) technology. Experience pure, high-fidelity sound with zero distractions for all your entertainment wherever you go
THX® CERTIFIED HEADPHONES
For high-fidelity sound. Tested and optimized by experts in cinematic audio immersion at THX Ltd., the headset presents a rich, balanced soundstage for all your movies, music and gaming.
ADVANCED ACTIVE NOISE CANCELLATION (ANC) TECHNOLOGY
For an uninterrupted audio experience on the go. Whether you’re watching a movie or rocking out to your favorite track, shut out all distractions with advanced ANC tech which detects and nullifies all incoming noise.
ENGINEERED FOR COMFORT
For long hours of wear. With plush leatherette memory foam ear cushions, a well-balanced weight and snug clamping force, you can keep the headphones on throughout long commutes and remain in supreme comfort.
WORKING FROM HOME NEVER SOUNDED BETTER
With four microphones dedicated to active noise cancellation and another two for voice communication, Razer Opus ensures you hear everyone in your conference calls and they hear you, both perfectly clear.
QUICK ATTENTION MODE
To stay aware of your surroundings. Press and hold the ANC button to instantly amplify ambient noise for a heightened sense of awareness—useful when crossing the road or to simply get a sense of your surroundings.
AUTO PAUSE/AUTO PLAY
To stop and start media seamlessly. Removing or resting these earphones around your neck pauses the audio. When you’re ready to continue, simply pop your headset back on and get right back into your movie or music.
PORTABLE DESIGN WITH 3.5MM JACK
For greater convenience when travelling. Able to work with most devices, the foldable headset comes with an airplane adapter and premium carry case—making it a perfect travel companion for frequent flyers.
Product Description | Razer Opus - headphones with mic | Product Type | Headphones - Bluetooth - wireless, wired - 3.5 mm jack | Recommended Use | Portable electronics | Colour | Black | Headphones Form Factor | Full size | Connectivity Technology | Wireless, wired | Wireless Technology | Bluetooth | Headphones Technology | Dynamic | Sound Output Mode | Stereo | Audio Specifications | Frequency Response 20 - 20000 Hz - Sensitivity 105 dB/mW | Impedance | 12 Ohm | Active Noise Canceling | Yes | Microphone Operation Mode | Omni-directional | Microphones Included | 2 | Controls | Power on/off, volume control, multiple function button, ANC/ambient | Manufacturer Warranty | 2-year warranty |
General | |
Weight | 265 g |
Colour | Black |
Headband Material | Leatherette |
Earpad Material | Memory foam, nylon, protein-leather, plush |
Audio Output | |
Headphones Cup Type | Closed |
Bluetooth Audio Codec | SBC, aptX |
Bluetooth Version | Bluetooth 4.2 |
Bluetooth Profiles | Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP) |
Active Noise Cancelling Technology | Advanced ANC |
Frequency Response | 20 - 20000 Hz |
Sensitivity | 105 dB/mW |
Diaphragm | 40 mm |
Adjustable Headband | Yes |
Features | Quick Attention function |
Microphone | |
Form Factor | Built-in |
Sensitivity | -38 dBV/Pascal |
Frequency Response | 100 - 10000 Hz |
Remote Control | |
Connections | |
Connector Type | Audio input (mini-phone stereo 3.5 mm) , USB (24 pin USB-C) |
Cable | |
Detachable Cable | Yes |
Miscellaneous | |
Included Accessories | Carrying case, USB-C charging cable, 3.5 mm audio cable (1.5 m) |
Cable Details | USB-C cable - detachable - 30 cm , Audio cable - detachable - L shaped / mini-phone stereo 3.5 mm - 1.5 m , USB-A to USB-C adapter - detachable , Airplane connection adapter - detachable |
Compliant Standards | THX Certified |
Power | |
Battery | Headphone battery rechargeable |
Run Time (Up To) | 25 hour(s) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
