Razer Universal Xbox Pro Charging Stand Shock Blue
FREE DELIVERY
PRICE DROP
WAS £44.99, SAVE £20
£24.99
Colours:
41 In Stock
Delivery:
Standard: 1-3 working days
Express: Delivered on Tuesday
Express Delivery:
  • 00
    h
  • 00
    m
  • 00
    s
Key features
  • Quick charge
  • Universal compatibility
  • Matches your Xbox Controller
  • Type: Power
Product codes
If you're looking for the fastest way to keep your Xbox controller at prime power levels, then go for the perfect pairing with the Razer universal quick charging stand for Xbox
Quick Charge
Able to fully charge your controller in under 3 hours, the stand is also designed with overcharge protection to prevent overheating and short circuiting
Universal Compatibility
Whether you're on next-gen, last-gen, or staying oldschool, the Razer Universal Quick Charging Stand for Xbox works with all controllers old and new.*
*Excluding Xbox Elite Controller Series 2
Magnetic Contact System
Mount your controller easily and never worry about its charge being interrupted thanks to a magnetic design that secures the controller to the stand.
To perfectly suit your setup, this charging stand uses the same durable material and shares the same striking colors as official Xbox Series X|S controllers.
Power By USB
Simply hook up the charging stand to your Xbox, PC, or compatible wall plugs to get it working.
What’s Inside
  • Razer Universal Quick Charging Stand for Xbox
    • Xbox Series X|S battery cover
    • Rechargeable battery
    • Xbox One battery cover
    • Important Product Information Guide
    • Type C to Type A cable
Promotions (1)
TRADE IN YOUR OLD CONSOLE
Got an old games console lying around?
When you trade in your old device at BT you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description Razer charging stand
Product Type Charging stand
Colour Shock blue
Designed For Microsoft Xbox One Wireless Controller, Wireless Controller
Manufacturer Warranty 1 Year
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£24.99
