Ring Alarm 5 Piece Starter Kit
FREE DELIVERY
£249.00
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Get notifications when doors or windows are opened or when motion is detected at your home when the system is armed
  • Monitor your home from any iOS or Android device
  • Control your entire home security from one simple app
  • Easy setup with no tools or professional installation required
  • 24-hour backup battery power and 104-decibel siren
  • Type: Home security system
  • Compatible With: Alexa
  • Stock Status: In Stock
Product codes
A smarter way to protect your property from the inside out. Effortless to install and completely customisable to fit any home. Includes:
  • Base Station
  • Keypad
  • 1 Contact Sensor
  • 1 Motion Detector
  • Range Extender
Product Description Ring Alarm Security Kit - 5-piece set - home security system
Product Type Home security system
Power Source Battery, power adapter
Intelligent Assistant Alexa
Package Content Door and window sensor, motion sensor, keypad, base station, extender
Connectivity Wireless, wired - ZigBee, Wi-Fi, Z-Wave - Ethernet
Siren Sound Level 104 dB
Input Type Keypad
Colour White
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Ring Alarm 5 Piece Sta...
£249.00
