Expand your Ring Alarm system to secure each door and window in your home, and get alerts as soon as they open. Ring Alarm Contact Sensors easily mount to any door or window frame in your home for easy, DIY installation. Connect them to your Ring Alarm Base Station and receive mobile alerts from the Ring app whenever your doors or windows open. You'll always be the first to know when something's ajar.
Product Description | Ring Alarm Contact Sensor - 2nd Generation - door and window sensor - Z-Wave - white | Product Type | Door and window sensor | Environment | Indoor | Power Source | Battery | Connectivity | Wireless - Z-Wave | Colour | White | Manufacturer Warranty | 1-year warranty | Dimensions (WxDxH) | 5.3 cm x 1.4 cm x 4 cm |
General | |
Connectivity Technology | Wireless - Z-Wave |
Max Range Open Space | 76.2 m |
Battery | |
Form Factor | CR2032 |
Battery Included | Yes |
Required Qty | 2 |
Battery Lifetime | 3 years |
Miscellaneous | |
Colour | White |
Dimensions & Weight | |
Width | 5.3 cm |
Depth | 1.4 cm |
Height | 4 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 49 °C |
