Take your siren outside. Enhance your Alarm Security System and let the neighbourhood know you have whole-home security covered. If there's an emergency, Outdoor Siren can help others quickly identify your home with an adjustable volume siren and flashing LED lights. Connect an additional compatible power source and turn on the Dusk to Dawn feature to use Alarm Outdoor Siren as an everyday security sign.
Dusk to Dawn. With the Dusk to Dawn feature, you can activate the logo light on a schedule in the Ring app. With Dusk to Dawn activated, your Outdoor Siren will be visible after dark and will let the neighbourhood know you have security covered.
To use the Dusk to Dawn feature you will need to power Outdoor Siren with a Quick Release Battery Pack combined with a Solar Panel for a continuous charge, or hardwired for non-stop power. Outdoor Siren also supports Ring Plug-in Adapter (2nd Generation) which allows you to power the Dusk to Dawn feature from an internal electrical socket.
Product Description | Ring Outdoor Siren - siren - Z-Wave - blue | Product Type | Siren | Environment | Outdoor | Power Source | Hardwired, battery | Connectivity | Wireless - Z-Wave | Siren Sound Level | 100 dB | Adjustments | Volume | Colour | Blue | Manufacturer Warranty | 1-year warranty | Dimensions (WxDxH) | 23.5 cm x 5.7 cm x 23.5 cm |
General | |
Connectivity Technology | Wireless - Z-Wave |
Max Range Open Space | 76 m |
Features | Wall mountable, visual alert, weather-resistant, Dusk to Dawn feature |
Battery | |
Form Factor | D type |
Battery Included | Yes |
Required Qty | 3 |
Battery Lifetime | 3 years |
Miscellaneous | |
Colour | Blue |
Dimensions & Weight | |
Width | 23.5 cm |
Depth | 5.7 cm |
Height | 23.5 cm |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 49 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
