Ring Alarm Range Extender
FREE DELIVERY
£29.00
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Feature bullets requires the ring alarm base station
  • Extends the signal from your alarm base station to alarm contact sensors, motion detectors and keypads
  • Provides a more reliable connection for your ring alarm system
  • Simple setup with no tools required
  • Plugs into standard power outlets
  • Type: Extender module
  • Stock Status: In Stock
Product codes
Add Range Extenders throughout your home to extend the signal from your Alarm Base Station to all Alarm components, so you can make sure your security coverage stays strong and clear.
*Requires the Ring Alarm Base Station.
Product Description Ring Alarm Range Extender - extender module
Product Type Extender module
Power Source Battery, power adapter
Connectivity Wireless - Z-Wave
Colour White
Manufacturer Warranty 1-year warranty
Dimensions (WxDxH) 4.6 cm x 2.8 cm x 8 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£29.00
