Add security anywhere – inside or out – with the versatile Stick Up Cam Battery. Its wire-free design means you can put it where you need it and move it when you need to. Place it on a flat surface for flexibility or mount it to a wall for a more permanent solution. With Stick Up Cam Battery, you’ll always be connected to home so you can see what’s happening at anytime.
Product Description | Ring Stick Up Cam Battery - 3rd Generation - network surveillance camera | Device Type | Network surveillance camera - fixed - outdoor, indoor - weatherproof | Audio | Yes: built-in speaker, two-way audio capability, built-in microphone | Camera Mount Type | Wall mount, ceiling mount | Dimensions (WxDxH) | 5.99 cm x 5.99 cm x 9.7 cm | Colour | White | Connectivity Technology | Wireless | Camera | Colour - Day&Night | Motion Detection | Yes | Video Modes | 1080p | Interfaces | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n | Intelligent Assistant | Alexa | Cables Included | 1 - micro-USB charge cable - external | Features | Smartphone Monitoring | Manufacturer Warranty | 1-year warranty | Environmental Parameters (operating) | -20.5 °C - 48.5 °C |
General | |
Device Type | Network surveillance camera |
Audio Support | Yes: built-in speaker, two-way audio capability, built-in microphone |
Width | 5.99 cm |
Depth | 5.99 cm |
Height | 9.7 cm |
Localisation | Europe |
Camera | |
Type | Colour - Day&Night - fixed - outdoor, indoor - weatherproof |
Digital Video Capture Resolution | 1920 x 1080 |
Lens Construction | |
Horizontal Field of View (degree) | 116 |
Vertical Field of View (degree) | 65 |
Interfaces | |
Network Interface | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Miscellaneous | |
Included Accessories | Mounting kit, base cover, rechargeable battery, security sticker, base pad |
Cables Included | 1 x micro-USB charge cable - external |
Colour | White |
Power | |
Battery | 1 |
Software / System Requirements | |
OS Required | Android 5.0 or later, Apple iOS 9.1 or later |
Internet of Things (IoT) | |
Intelligent Assistant Compatible | Alexa |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | -20.5 °C |
Max Operating Temperature | 48.5 °C |
