Ring All-new Stick Up Cam Plug-in
FREE DELIVERY
£89.00
Select:
20 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Goes everywhere
  • Complete control
  • Works with Stick Up Cam
  • Stock Status: In Stock,
    Used stock also available below
Product codes
Add security anywhere – inside or out – with the versatile Stick Up Cam Battery. Its wire-free design means you can put it where you need it and move it when you need to. Place it on a flat surface for flexibility or mount it to a wall for a more permanent solution. With Stick Up Cam Battery, you’ll always be connected to home so you can see what’s happening at anytime.
Goes everywhere. Sees everything.
Add eyes and ears inside or out with the versatile camera that goes almost anywhere. With countless placement options and customisable motion settings, you can find your perfect setup for you and your home.
Cover every corner.
Up high. Mount it on the side of your garage, or to a wall in the living room. Make sure the pets don’t get into too much trouble, or check to see if there’s anyone snooping in your garden.
Down low. It also goes on a flat surface like a coffee table inside, or your patio outside. Watch the pets play at home while you’re at work, or just make sure there’s no one sneaking down your driveway.
Complete control. One simple app.
Connected Devices - Connect to all your Ring devices to see what’s happening from a single dashboard and to control everything from one simple app.
Product Description Ring Stick Up Cam Plug-In - 3rd Generation - network surveillance camera
Device Type Network surveillance camera - fixed - outdoor, indoor - weatherproof
Audio Yes: two-way audio capability
Camera Mount Type Wall mount, ceiling mount
Dimensions (WxDxH) 6 cm x 6 cm x 9.7 cm
Colour White
Connectivity Technology Wired, wireless
Camera Colour - Day&Night
Motion Detection Yes
Video Modes 1080p
Interfaces Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11a
Cables Included 1 - micro-USB cable - external
Voltage USB / PoE
Features Audio Noise Reduction
Manufacturer Warranty 1-year warranty
Environmental Parameters (operating) -20.5 °C - 48.5 °C
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used and shows signs of use European plug only.
Ref: FGDL 041706
£73.68
product
Ref: FGDL 041706
Accessories
Packaging
Functional
Software
Manuals
£73.68
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Ring All-new Stick Up...
£89.00
