Ring Chime Pro
FREE DELIVERY
Ring Chime Pro
£49.00
10 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Boosts Ring's network signal
  • Multiple alert tones
  • Volume control
  • Do not disturb mode
  • Plugs into standard power outlet
  • Type: Signal repeater / doorbell
  • Compatible With: Alexa, IFTTT, SmartThings
  • Stock Status: In Stock, Used Stock
Product codes
Chime Pro
Wi-Fi extender and indoor Chime for Ring devices.
Wi-Fi Extender and Indoor Chime for Ring Devices
Chime Pro extends your Wi-Fi signal and amplifies your Ring alerts. Plug Chime Pro into any standard power outlet, link it to all your Ring devices, and get Ring alerts anywhere in your home.
- Boosts Ring's Network Signal
- Multiple Alert Tones
- Volume Control
- Do Not Disturb Mode
Extend Your Ring Network
Chime Pro extends the signal from your router to your Ring devices, so you can eliminate Wi-Fi dead zones and never miss a Ring alert.
Product Description Ring Chime PRO - signal repeater / doorbell
Product Type Signal repeater / doorbell
Environment Indoor
Connectivity Wireless - 802.11b/g/n
Frequency Band 2.4 Ghz
Dimensions (WxDxH) 7.4 cm x 4.7 cm x 2.6 cm
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: D39R 040161
£34.14
product
Ref: D39R 040161
Accessories
Packaging
Functional
Software
Manuals
£34.14
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Ring Chime Pro
£49.00
