Ring Floodlight Camera - White
FREE DELIVERY
£249.00
Colours:
11 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Crystal clear HD video
  • Ultra-bright LED floodlights
  • Loud siren alarm
  • Type: Outdoor Camera
  • Compatible With: Alexa
  • Stock Status: In Stock,
    Used stock also available below
Product codes
Floodlight Cam
The world's only motion-activated HD security camera with built-in floodlights, a siren alarm and two-way talk.
Requires professional installation by a qualified electrician.
The Evolution of Outdoor Security
Protect your home with the world’s only motion-activated security camera with built-in floodlights, a siren alarm and two-way audio, so you can see, hear and speak to anyone on your property from anywhere.
- Crystal-clear HD video
- Two ultra-bright LED floodlights
- 110-decibel siren alarm
Watch Over Your Entire Property
With object and facial detection, Floodlight Cam has the most advanced motion sensors in home security. Its 270° field-of-view will let you detect motion around corners and monitor all your blind spots.
- Dual sensors with object and facial detection
- Ultra wide-angle motion sensors
- Customizable motion zones and scheduling
Simple Setup With Advanced Controls
Floodlight Cam easily replaces existing wired floodlights and connects to standard junction boxes. With the app, you can flash the lights, sound the alarm and zoom-in to focus on your most important areas.
- Motion-activated camera and floodlights
- App-controlled camera, lights and siren
- Smart zoom with panning
Home Security at Your Fingertips
Floodlight Cam sends instant alerts to your smartphone, tablet or PC whenever it detects motion. And from the free Ring app, you can protect your property and monitor your home from anywhere.
- Instant motion-activated alerts
- Live View streaming video and audio
- iOS, Android, Mac and Windows 10 compatible
Ring Protect Plans
Real-time Ring alerts, Real-time motion alerts, Custom motion detection, Two-way talk, Live View and Theft Protection are included as standard with all Ring products. All Ring products come with a 2 year warranty.
If you want to store, review, share and download videos from your events you will need to purchase a Ring Protect Plan, available from £2.50 per month. These are available from https://en-uk.ring.com/pages/protect-plans.
Product Description Ring Floodlight Cam - network surveillance camera
Device Type Network surveillance camera - fixed - outdoor - weatherproof
Audio Yes: built-in speaker, built-in microphone
Dimensions (WxDxH) 6.9 cm x 6.9 cm x 12.5 cm
Colour White
Connectivity Technology Wireless
Camera Colour - Day&Night
Video Modes 1080p
Interfaces IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage AC 120/230 V
Features Motion sensor, Object Detection, Face Recognition, built-in siren
Manufacturer Warranty 2 year warranty
Environmental Parameters (operating) -28 °C - 48 °C
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item shows signs of use but is in excellent condition
Ref: D305 042510
£154.44
product
Ref: D305 042510
Accessories
Packaging
Functional
Software
Manuals
£154.44
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Ring Floodlight Camera...
£249.00
