Ring Stick Up Cam Battery - Black
FREE DELIVERY
£179.00
Colours:
25 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered on Tuesday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Protection anytime, anyplace
  • Stick it up anywhere you need it
  • Smarter security in just minutes
  • Take charge with battery power
  • Extra peace of mind with Ring Protect Plans
  • Alexa, show me my Stick Up Cam
  • Get security powered by the sun
  • Type: Indoor Camera, Outdoor Camera
  • Compatible With: Alexa, Google Assistant, IFTTT, SmartThings
  • Stock Status: In Stock, Used Stock
Product codes
Battery-powered indoor/outdoor HD camera with two-way talk, a siren and versatile mounting options.
Protection anytime, anywhere.
Get notifications when people and pets come and go. See, hear and speak to anyone on camera. And sync all your Ring devices to the app to control your entire home security with one simple dashboard. All from your phone or tablet. Compatible with iOS, Android and Mac devices.
Stick it up anywhere you need it.
Outside above your porch. Inside on a wall. Or anywhere on a flat surface. Place the all-new Stick Up Cam where you need it, move it when you need to, or mount it when you need something permanent.
Smarter security in just minutes.
Install your Stick Up Cam almost anywhere with the included toolkit, packed with everything you need to set it up in minutes. Then use the adjustable mounting bracket to find your ideal setting.
Take charge with battery power.
Use the quick-release battery pack to easily charge your camera without moving the device. Swap it into any other battery-powered Ring device for convenient security. And get an extra battery pack so you’ll always have backup power.
‘Alexa, show me my Stick Up Cam.’
Get smart security at the sound of your voice, and combine Stick Up Cam with select Alexa devices to launch real-time video from the comfort of your couch. Want to see who’s there? Just ask Alexa.
Get security powered by the sun.
Add a compatible Ring Solar Panel (sold separately) to your Stick Up Cam Battery for a consistent hands-free charge. With only a few hours of direct sunlight every day, you’ll have protection around the clock.
Ring Protect Plans
Real-time Ring alerts, Real-time motion alerts, Custom motion detection, Two-way talk, Live View and Theft Protection are included as standard with all Ring products. All Ring products come with a 2 year warranty.
If you want to store, review, share and download videos from your events you will need to purchase a Ring Protect Plan, available from £2.50 per month. These are available from https://en-uk.ring.com/pages/protect-plans.
Product Description Ring Stick Up Cam Battery - network surveillance camera
Device Type Network surveillance camera - fixed - outdoor, indoor - weatherproof
Audio Yes: built-in speaker, two-way audio capability, built-in microphone
Dimensions (WxDxH) 5.99 cm x 5.99 cm x 9.7 cm
Weight 454 g
Colour Black
Connectivity Technology Wireless
Camera Colour - Day&Night
Motion Detection Yes
Video Modes 1080p
Interfaces IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Cables Included 1 - micro-USB charge cable - external
Features Built-in siren
Manufacturer Warranty 2 year warranty
Environmental Parameters (operating) -20.5 °C - 48.5 °C
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: DZGF 040589
£135.94
product
Ref: DZGF 040589
Accessories
Packaging
Functional
Software
Manuals
£135.94
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Ring Stick Up Cam Batt...
£179.00
