White
Add security anywhere – inside or out – with the versatile Stick Up Cam Battery. Its wire-free design means you can put it where you need it and move it when you need to. Place it on a flat surface for flexibility or mount it to a wall for a more permanent solution. With Stick Up Cam Battery, you’ll always be connected to home so you can see what’s happening at anytime.
Product Description | Ring Stick Up Cam Battery - network surveillance camera | Device Type | Network surveillance camera - fixed - outdoor, indoor - weatherproof | Audio | Yes: built-in speaker, two-way audio capability, built-in microphone | Camera Mount Type | Surface mount, wall mount | Dimensions (WxDxH) | 5.99 cm x 5.99 cm x 9.7 cm | Weight | 154 g | Colour | White | Connectivity Technology | Wireless | Camera | Colour - Day&Night | Motion Detection | Yes | Video Modes | 1080p | Interfaces | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n | Intelligent Assistant | Alexa | Cables Included | 1 - micro-USB charge cable - external | Features | Smartphone Monitoring | Manufacturer Warranty | 1-year warranty | Environmental Parameters (operating) | -20 °C - 50 °C |
General | |
Device Type | Network surveillance camera |
Audio Support | Yes: built-in speaker, two-way audio capability, built-in microphone |
Width | 5.99 cm |
Depth | 5.99 cm |
Height | 9.7 cm |
Weight | 154 g |
Camera | |
Type | Colour - Day&Night - fixed - outdoor, indoor - weatherproof |
Digital Video Capture Resolution | 1920 x 1080 |
Lens Construction | |
Horizontal Field of View (degree) | 110 |
Vertical Field of View (degree) | 57 |
Diagonal Field of View (degree) | 130 |
Interfaces | |
Network Interface | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Miscellaneous | |
Included Accessories | Mounting kit, rechargeable battery, security sticker |
Cables Included | 1 x micro-USB charge cable - external |
Colour | White |
Power | |
Battery | 1 |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 50 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
