Add security anywhere – inside or out – with the versatile Stick Up Cam Battery. Its wire-free design means you can put it where you need it and move it when you need to. Place it on a flat surface for flexibility or mount it to a wall for a more permanent solution. With Stick Up Cam Battery, you’ll always be connected to home so you can see what’s happening at anytime.
Goes everywhere. Sees everything.
Add eyes and ears inside or out with the versatile camera that goes almost anywhere. With countless placement options and customisable motion settings, you can find your perfect setup for you and your home.
Cover every corner.
Up high. Mount it on the side of your garage, or to a wall in the living room. Make sure the pets don’t get into too much trouble, or check to see if there’s anyone snooping in your garden.
Down low. It also goes on a flat surface like a coffee table inside, or your patio outside. Watch the pets play at home while you’re at work, or just make sure there’s no one sneaking down your driveway.
Complete control. One simple app.
Connected Devices - Connect to all your Ring devices to see what’s happening from a single dashboard and to control everything from one simple app.
Product Description | Ring Stick Up Cam Battery - 3rd Generation - network surveillance camera | Device Type | Network surveillance camera - fixed - outdoor, indoor - weatherproof | Audio | Yes: built-in speaker, two-way audio capability, built-in microphone | Camera Mount Type | Wall mount, ceiling mount | Dimensions (WxDxH) | 5.99 cm x 5.99 cm x 9.7 cm | Colour | White | Connectivity Technology | Wireless | Camera | Colour - Day&Night | Motion Detection | Yes | Video Modes | 1080p | Interfaces | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n | Intelligent Assistant | Alexa | Cables Included | 1 - micro-USB charge cable - external | Features | Smartphone Monitoring | Manufacturer Warranty | 1-year warranty | Environmental Parameters (operating) | -20.5 °C - 48.5 °C |
General | |
Device Type | Network surveillance camera |
Audio Support | Yes: built-in speaker, two-way audio capability, built-in microphone |
Width | 5.99 cm |
Depth | 5.99 cm |
Height | 9.7 cm |
Localisation | Europe |
Camera | |
Type | Colour - Day&Night - fixed - outdoor, indoor - weatherproof |
Digital Video Capture Resolution | 1920 x 1080 |
Lens Construction | |
Horizontal Field of View (degree) | 116 |
Vertical Field of View (degree) | 65 |
Interfaces | |
Network Interface | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Miscellaneous | |
Included Accessories | Mounting kit, base cover, rechargeable battery, security sticker, base pad |
Cables Included | 1 x micro-USB charge cable - external |
Colour | White |
Power | |
Battery | 1 |
Software / System Requirements | |
OS Required | Android 5.0 or later, Apple iOS 9.1 or later |
Internet of Things (IoT) | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | -20.5 °C |
Max Operating Temperature | 48.5 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
