Battery-powered indoor/outdoor HD camera with two-way talk, a siren and versatile mounting options.
Protection anytime, anywhere.
Get notifications when people and pets come and go. See, hear and speak to anyone on camera. And sync all your Ring devices to the app to control your entire home security with one simple dashboard. All from your phone or tablet. Compatible with iOS, Android and Mac devices.
Stick it up anywhere you need it.
Outside above your porch. Inside on a wall. Or anywhere on a flat surface. Place the all-new Stick Up Cam where you need it, move it when you need to, or mount it when you need something permanent.
Smarter security in just minutes.
Install your Stick Up Cam almost anywhere with the included toolkit, packed with everything you need to set it up in minutes. Then use the adjustable mounting bracket to find your ideal setting.
Take charge with battery power.
Use the quick-release battery pack to easily charge your camera without moving the device. Swap it into any other battery-powered Ring device for convenient security. And get an extra battery pack so you’ll always have backup power.
‘Alexa, show me my Stick Up Cam.’
Get smart security at the sound of your voice, and combine Stick Up Cam with select Alexa devices to launch real-time video from the comfort of your couch. Want to see who’s there? Just ask Alexa.
Get security powered by the sun.
Add a compatible Ring Solar Panel (sold separately) to your Stick Up Cam Battery for a consistent hands-free charge. With only a few hours of direct sunlight every day, you’ll have protection around the clock.
Ring Protect Plans
Real-time Ring alerts, Real-time motion alerts, Custom motion detection, Two-way talk, Live View and Theft Protection are included as standard with all Ring products. All Ring products come with a 2 year warranty.
If you want to store, review, share and download videos from your events you will need to purchase a Ring Protect Plan, available from £2.50 per month. These are available from https://en-uk.ring.com/pages/protect-plans.
Product Description | Ring Stick Up Cam Battery - network surveillance camera | Device Type | Network surveillance camera - fixed - outdoor, indoor - weatherproof | Audio | Yes: built-in speaker, two-way audio capability, built-in microphone | Dimensions (WxDxH) | 5.99 cm x 5.99 cm x 9.7 cm | Weight | 454 g | Colour | White | Connectivity Technology | Wireless | Camera | Colour - Day&Night | Motion Detection | Yes | Video Modes | 1080p | Interfaces | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n | Cables Included | 1 - micro-USB charge cable - external | Features | Built-in siren | Manufacturer Warranty | 2 year warranty | Environmental Parameters (operating) | -20.5 °C - 48.5 °C |
General | |
Device Type | Network surveillance camera |
Audio Support | Yes: built-in speaker, two-way audio capability, built-in microphone |
Width | 5.99 cm |
Depth | 5.99 cm |
Height | 9.7 cm |
Weight | 454 g |
Camera | |
Type | Colour - Day&Night - fixed - outdoor, indoor - weatherproof |
Lens Construction | |
Horizontal Field of View (degree) | 116 |
Vertical Field of View (degree) | 65 |
Interfaces | |
Network Interface | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Miscellaneous | |
Included Accessories | Mounting kit, base cover, rechargeable battery, security sticker, base pad |
Cables Included | 1 x micro-USB charge cable - external |
Colour | White |
Internet of Things (IoT) | |
Intelligent Assistant Compatible | Alexa |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 year |
Environmental Parameters | |
Min Operating Temperature | -20.5 °C |
Max Operating Temperature | 48.5 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
