Ring Stick up Cam Plug-in - Black
FREE DELIVERY
PRICE DROP
LIMITED TIME OFFER
EASTER SALE - USUALLY £89
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00
    h
  • 00
    m
  • 00
    s
Key features
  • HD Video
  • Indoor/Outdoor
  • Plug-In Power
  • Motion-Activated Notifications
  • Night Vision
  • Easy Installation
  • Type: Indoor Camera
  • Compatible With: Alexa
Product codes
Get non-stop power for non-stop peace of mind with a motion-activated camera that goes anywhere, inside or out. It installs in minutes and plugs into standard UK power sockets, so you’ll never have to worry about charging a battery. Place it on a flat surface for flexibility or on a wall for a secure mount. Wherever you are, Stick Up Cam Plug-In lets you check in on your home at any time.
Goes everywhere. Sees everything.
With countless placement options and customisable motion settings, find the perfect setup for you and your home.
Cover Every Corner
Up high. Mount it on the side of your garage, or to a wall in the living room. Make sure the pets don’t get into too much trouble, or check to see if there’s anyone snooping in your garden.
Down low. It also goes on a flat surface like a coffee table inside, or your patio outside. Watch the pets play at home while you’re at work, or just make sure there’s no one sneaking down your driveway.
Complete control from the Ring app.
The Ring app unlocks all the features your devices have to offer so you can protect your home, your way.
Product Description Ring Stick Up Cam Plug-In - 3rd Generation - network surveillance camera
Device Type Network surveillance camera - fixed - outdoor, indoor - weatherproof
Audio Yes: two-way audio capability
Camera Mount Type Wall mount, ceiling mount
Dimensions (WxDxH) 6 cm x 6 cm x 9.7 cm
Colour Black
Connectivity Technology Wired, wireless
Camera Colour - Day&Night
Motion Detection Yes
Video Modes 1080p
Interfaces IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Features Audio Noise Reduction
Manufacturer Warranty 1-year warranty
Environmental Parameters (operating) -20 °C - 50 °C
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£59.00
