Double up on convenience. The DUO Plus is a Type-C drive with a super-useful Type-A adapter. Eliminate worries as the intuitive integrated Type-A adapter works with your older devices. You can flexibly move data and free up space with superior speed and performance.
Product Description | Samsung DUO Plus MUF-128DB - USB flash drive - 128 GB | Product Type | USB flash drive | Interface Type | USB 3.1 / USB-C | Storage Capacity | 128 GB | Manufacturer Warranty | 5-year warranty |
General | |
Compatibility | Non-specific |
Memory | |
Read Rate | Up to 300 MB/s |
Features | Shockproof, magnetic-proof, water resistant, X-ray-proof, temperature-proof |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Dimensions & Weight | |
Width | 57.9 mm |
Depth | 18.3 mm |
Height | 7.37 mm |
Weight | 7.7 g |
Environmental Parameters | |
Min Operating Temperature | -25 °C |
Max Operating Temperature | 85 °C |
