Samsung 1TB 970 EVO V-NAND M.2 NVMe Phoenix Controller SSD
£165.58
Select:
47 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Fast SSD speed
  • Design flexibility
  • Exceptional endurance
  • Form Factor: M.2 2280
  • Capacity: 1TB, 1TB
  • Interface: Serial ATA-600
  • Type: Internal hard drive
  • Stock Status: In Stock
Product codes
THE SAMSUNG SSD 970 EVO
The Samsung SSD 970 EVO is the 2nd generation of Samsung’s 3bit-MLC NVMe SSDs for client PC. The Samsung 970 EVO is specially designed for tech savvies, gamers and professionals who frequently work on video creation/editing or simulation that requires high workloads. Featuring the latest Samsung 3bit-MLC V-NAND technology and a newly enhanced Phoenix controller, the 970 EVO delivers unrivaled next level performance and exceptional reliability in a small M.2 2280 form factor, offering customers the most advanced Samsung SSD technology currently available for Client PCs.
Next Level SSD Speed
In combination with the latest Samsung V-NAND technology, powerful Phoenix Controller and upgraded Intelligent TurboWrite technology, the 970 EVO delivers stunning sequential read/write performance of up to 3,500/2,500 MB/s respectively and random performance of up to 500,000/480,000 IOPS for read/write respectively. Upgraded Intelligent TurboWrite technology uses a large buffer size of up to 78GB to enable faster sequential write speeds, which improves the user experience especially when transferring large files or using application which requires high-workloads.
Unparalleled Reliability
The 970 EVO boasts exceptional endurance with up to 1,200 TBW, which is 50 percent higher than that of the previous model, thanks to the latest Samsung V-NAND technology.* Thermal control solutions enable enhanced performance with reduced heat risk. Dynamic Thermal Guard(DTG) technology proactively prevents overheating, and a heat spreader with an integrated thin copper film dissipates heat more efficiently. A new nickel coating on the Phoenix controller also helps to shed heat faster during heavy workload use in order to ensure the high levels of quality and reliability for which Samsung is known. The 970 EVO offers more time period of 5-year warranty versus that of 960 EVO. *All documented endurance test results are obtained in compliance with JESD218 standards. Please visit www.jedec.org for detailed information on the standard.
System Design Flexibility
The 970 EVO enables convenient storage expansion across many different devices. The 970 EVO comes in a broad range of capacity options, including a single-sided 2TB version, made possible through Samsung’s latest 512Gb V-NAND technology. In addition, the 970 EVO offers high power efficiency as well as exceptional speeds, making it the ideal solution to use with application ranging from ultra-thin computing to high-performance computing systems. Advanced Data Encryption The 970 EVO provides multiple advanced data encryption features. Self-Encrypting Drive (SED) security technology will help keep data safe at all times. The 970 EVO includes an AES 256-bit hardware-based encryption engine to ensure that your personal files remain secure. Being hardware-based, the encryption engine secures your data without the performance degradation that you may experience with software-based encryption. Also, the 970 EVO is compliant with various advanced security management solutions (TCG Opal and Encrypted Drive-IEEE1667).
Samsung Data Migration and Magician Software
The 970 EVO comes with Samsung Data Migration and Magician software, which is easy to install and makes management of your SSD simple.* Samsung Data Migration software is easy to use, yet provides a very powerful "Custom Cloning" feature that makes migration effortless even when the amount of source data is greater than the SSD’s capacity. Magician provides personalized firmware checks and additional functionality tailored to the drives of individual users. It even updates the firmware automatically to make sure that the drive’s performance stays up to date.
*To download Samsung Data Migration and Magician, please visit www.samsung.com/samsungssd
Product Description Samsung 970 EVO MZ-V7E1T0BW - solid state drive - 1 TB - PCI Express 3.0 x4 (NVMe)
Type Solid state drive - internal - TRIM support, Microsoft eDrive compatible, Auto Garbage Collection Algorithm, V-NAND Technology, Temperature Monitoring, NVM Express (NVMe) 1.3, Samsung Phoenix Controller
Capacity 1 TB
Hardware Encryption Yes
Encryption Algorithm 256-bit AES
NAND Flash Memory Type 3D multi-level cell (MLC)
Form Factor M.2 2280
Interface PCI Express 3.0 x4 (NVMe)
Features TRIM support, Microsoft eDrive compatible, Auto Garbage Collection Algorithm, V-NAND Technology, Temperature Monitoring, NVM Express (NVMe) 1.3, Samsung Phoenix Controller, S.M.A.R.T.
Dimensions (WxDxH) 2.21 cm x 8.03 cm x 0.23 cm
Weight 7.94 g
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung 1TB 970 EVO V-...
£165.58
