Samsung 1TB T5 Series USB 3.1 Type-C External Portable SSD
£163.08
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Fast transfer speeds
  • Metal minimalism
  • Compact and light
  • Solid inside and out
  • Connect with ease
  • Form Factor: 2.5"
  • Capacity: 1TB, 1TB
  • Interface: USB 3.1 Gen 2
  • Type: External hard drive
  • Stock Status: In Stock
Product codes
Storage Redefined
The Samsung Portable SSD T5 elevates data transfer speeds to the next level and unleashes a new experience in external storage. With a compact and durable design and password protection, the T5 is truly easy to carry and stores data securely.
Fast Transfer Speeds
With Samsung V-NAND flash memory and a USB 3.1 Gen2 interface, the T5 provides fast transfer speeds of up to 540MB/s, that's up to 4.9x faster than external HDDs. Transfers and backups of large-sized data including 4K videos and high-resolution photos will be much quicker and faster.
Download times from laptop to T5:
4.8GB 4K UHD Movie - 12 seconds
3GB Full HD Movie - 7 seconds
100 Photos (2.8MB each) - 3 seconds
Metal Minimalism
The top to bottom metal design and rounded unibody fits comfortably in the palm of your hand. The T5 comes in two distinct aluminum finishes - an alluring blue for 250GB and 500GB models, and a deep black for 1TB and 2TB models.
Compact and Light
Smaller than the average business card, weighing just 51 grams, and only 10.5mm thick. The compact, light and slim T5 is the perfect portable storage.
Solid Inside and Out
Stay worry-free. The T5 has no moving parts and a sturdy metal body, so it can handle drops of up to 2 metres. The optional password protection with AES 256-bit hardware encryption keeps your personal and private data more secure. It's all confidently backed by a 3-year limited warranty.
Management Software
The T5 comes embedded with new intuitive software for PCs and Macs to easily set the password and get the latest firmware updates. You can also download the mobile app for Android smartphones and tablets.
Connect with ease
Connect the T5 to an extensive range of devices from PCs, Macs, smartphones and other devices. The included USB Type C to C cable and USB Type C to A cable give you seamless connectivity without the hassle of purchasing additional adapters.
Ready anytime, anywhere
Take everything, all your work and entertainment, with you. The Portable SSD T5 gives you simple and efficient access to your massive data so you can complete tasks quickly and on the move. Take along your documents, large-sized photos or videos, and get things done wherever you go.
Storage Capacity
1TB:
4K UHD Video - 3840 x 1600 (24fps), 4.83GB, 1:48:53 - 340 hours
HD Video - 1920 x 804 (24fps), 2.99GB, 1:58:36 - 610 hours
Photos - 2.8MB each - 340,000
Product Description Samsung Portable SSD T5 MU-PA1T0 - solid state drive - 1 TB - USB 3.1 Gen 2
Type Solid state drive - external (portable) - shock resistant, password authentication, USB Attached SCSI Protocol (UASP) compliant, V-NAND Technology
Capacity 1 TB
Hardware Encryption Yes
Encryption Algorithm 256-bit AES
Interface USB 3.1 Gen 2 - USB-C
Features Shock resistant, password authentication, USB Attached SCSI Protocol (UASP) compliant, V-NAND Technology, 256-bit AES
Power Source USB bus
Enclosure Colour Deep black
Dimensions (WxDxH) 7.4 cm x 1.05 cm x 5.73 cm
Weight 51 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung 1TB T5 Series...
£163.08
