165 Hz refresh rate and 1 ms response time makes it perfect for crisp and smooth gameplay - you'll appreciate that extra in fast-paced online titles like CS:GO or Valorant
AMD Freesync Premium technology takes care of screen tearing, blurring and other artefacts for smooth action in games, even if your framerate dips lower now and then
Full HD VA screen boasts sharp contrast, deep blacks and wide viewing angles, so it even looks great from the side
Fully adjustable stand lets you to get the viewing angle just right, so you can keep a healthy posture throughout your gaming marathons
This monitor has low blue light and is flicker free, so it goes easy on your eyes
Product Description | Samsung Odyssey G3 S24AG320NU - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class E | Energy Consumption per Year | 23 kWh | Adaptive-Sync Technology | AMD FreeSync Premium | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 165 Hz | Pixel Pitch | 0.2767 mm | Brightness | 250 cd/m² | Contrast Ratio | 3000:1 | Response Time | 1 ms (MPRT) | Colour Support | 16.7 million colours | Colour Gamut | 72% NTSC | Input Connectors | HDMI, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 100-240 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 54.4 cm x 23.42 cm x 49.87 cm | Weight | 4.5 kg | Manufacturer Warranty | 2-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Panel Type | VA |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Game mode, Mega Dynamic Contrast Ratio, Black eQualizer, Flicker Free technology, Eco Saving Plus, Eye Saver Mode, Off Timer Plus, Refresh Rate Optimizer, 3 Side Borderless Design |
Colour | Black |
Dimensions (WxDxH) | 54.4 cm x 23.42 cm x 49.87 cm - with stand |
Weight | 4.5 kg |
Connectivity | |
Interfaces | HDMI , DisplayPort 1.2 , Headphones |
Mechanical | |
Tilt Angle | -5/+20 |
Swivel Angle | 30 |
Rotation Angle | -2/+92 |
Height Adjustment | 120 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x DisplayPort cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 100-240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 16 kWh/1000h |
Power Consumption (Typical) | 16 Watt |
Power Consumption (Max) | 25 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 54.4 cm - depth: 23.42 cm - height: 49.87 cm - weight: 4.5 kg , Without stand - width: 54.4 cm - depth: 9.2 cm - height: 33.33 cm - weight: 3 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 63.6 cm |
Shipping Depth | 45.4 cm |
Shipping Height | 21.15 cm |
Shipping Weight | 6.6 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
