Samsung's 24x Serial SATA DVD Writer supports powerful over speed performance which allows writing with the high speed of 24x on a low cost 16x media.
Write Speed
Read Speed
| Product Description | Samsung Super-WriteMaster SH-224DB - DVD±RW (±R DL) / DVD-RAM drive - Serial ATA - internal | Device Type | DVD±RW (±R DL) / DVD-RAM drive - internal | Colour | Black, white, silver | Image Colour Disclaimer | The displayed product image may be a different colour | Interface | Serial ATA | Dimensions (WxDxH) | 14.82 cm x 17 cm x 4.2 cm | Weight | 750 g | Optical Storage | DVD±RW (±R DL) / DVD-RAM - 5.25" x 1/2H | Read Speed | 48x (CD) / 16x (DVD) | Write Speed | 48x (CD) / 24x (DVD±R) / 8x (DVD±R DL) | CD / DVD Rewrite Speed | 6x (DVD-RW) / 8x (DVD+RW) / 12x (DVD-RAM) | Buffer Underrun Protection | Yes | Media Load Type | Tray |
General | |
| Width | 14.82 cm |
| Depth | 17 cm |
| Height | 4.2 cm |
| Weight | 750 g |
Optical Storage | |
| Type | DVD±RW (±R DL) / DVD-RAM - 5.25" x 1/2H |
| Supported Media Formats | CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Mixed-mode CD, Photo CD, CD-ROM, CD+G (Karaoke CD), DVD-Video |
| Supported Media Types | CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL, DVD-ROM DL |
| Access Time | 150 ms (DVD), 170 ms (CD) |
| Buffer Size | 1.5 MB |
| Features | Speed Adjustment Technology (SAT), Tilt Actuator Compensation (TAC), Double Optimum Power Control, firmware upgradable, Speed Plus |
| Compliant Standards | CD-Bridge |
Expansion / Connectivity | |
| Interfaces | 1 x Serial ATA-150 - 7 pin Serial ATA |
| Compatible Bay | 1 x 5.25" x 1/2H - front accessible |
Miscellaneous | |
| Included Accessories | 3 colour bezels |
| Compliant Standards | RoHS |
| Package Type | Retail |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
