Escape into reality-defying realism. You can see games like never before. IPS panel delivers clear colors and a wide 178º viewing angle for clarity from any viewpoint. With more pixels and greater depth, games are closer to reality than ever before.
Keep your eye on the win. Adjust your screen to 21:9 to discover hidden areas in game scenes with ultrawide game view. Now when you play football games, you can see more of the pitch right up to the goalposts. And in driving games, get a natural and encompassing view of the road ahead.
Product Description | Samsung Odyssey G4 S25BG400EU - G40B Series - LED monitor - Full HD (1080p) - 25" - HDR | Device Type | LED-backlit LCD monitor - 25" | Energy Class | Class E | Energy Consumption per Year | 26 kWh | Adaptive-Sync Technology | NVIDIA G-SYNC Compatible, AMD FreeSync Premium | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 240 Hz | Brightness | 400 cd/m² | Contrast Ratio | 1000:1 | HDR Capable | HDR10 | Response Time | 1 ms (grey-to-grey) | Gaming | Yes | Colour Support | 16.7 million colours | Colour Gamut | 99% sRGB | Input Connectors | 2xHDMI, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 100-240 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 55.85 cm x 24.48 cm x 55.29 cm | Weight | 4.5 kg | Compliant Standards | HDCP 2.2 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 25" |
Panel Type | IPS |
HDR Format | HDR10 |
Gaming | Yes |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Cinema Mode, Eco Light Sensor, CustomColor Mode, FPS Mode, Mega Infinity Dynamic Contrast Ratio, Flicker Free technology, RTS Mode, Eco Saving Plus, Eye Saver Mode, Sports Mode, Low Input Lag, Super Arena Gaming UX, Refresh Rate Optimizer, RPG Mode, sRGB Mode, Off Timer, Dynamic Contrast Mode, Auto Source Switch+, Adaptive Picture, Ultrawide Game View, ergonomic stand, Virtual AIM Point |
Colour | Black |
Dimensions (WxDxH) | 55.85 cm x 24.48 cm x 55.29 cm - with stand |
Weight | 4.5 kg |
Connectivity | |
Interfaces | DisplayPort 1.2 , 2 x HDMI , Headphones |
Mechanical | |
Tilt Angle | -3/+22 |
Swivel Angle | 30 |
Rotation Angle | -92/+92 |
Height Adjustment | 120 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Cables Included | 1 x HDMI cable |
Power | |
Input Voltage | AC 100-240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 18 kWh/1000h |
Power Consumption HDR (On mode) | 31 kWh/1000h |
Power Consumption (Typical) | 18 Watt |
Power Consumption (Max) | 35 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 55.85 cm - depth: 24.48 cm - height: 55.29 cm - weight: 4.5 kg , Without stand - width: 55.85 cm - depth: 8.54 cm - height: 34.11 cm - weight: 2.8 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 62.8 cm |
Shipping Depth | 42.9 cm |
Shipping Height | 16.3 cm |
Shipping Weight | 6 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
