Samsung 256GB 850 Pro SATA 6GB/s 2.5" Solid State Drive
Ultimate Read/Write Performance
Key features
  • Ultimate read/write performance
  • Enhanced endurance and reliability
  • Efficient power management
Product codes
The Samsung 850 PRO SSD redefines storage with the world's first drive based on 3D VNAND flash, offering exceptional read/write performance, reliability and power management efficiency. The 850 Pro delivers up to 2x the speed, density and endurance of conventional flash.
  • The World's First Consumer 3D V-NAND SSD
  • Ultimate Read/Write Performance
  • Enhanced Endurance and Reliability
  • Efficient Power Management
Samsung's 850 PRO, the world's first 32 layer 3D V-NAND, provides up to 100K IOPS Random Read Speed and 470 MB/s Sequential Write speed and the option of enabling Samsung RAPID mode, which can kick up to even higher speeds. With up to 2x the speed and density of conventional 2D flash, you get the most speed available for gaming and real world performance
With an industry-leading 10 year, 150 TBW warranty, the 850 PRO offers unbeatable reliability. When combined with the 850 PRO's 256-bit AES Self-Encrypting Drive (SED) security technology, you can rely on your files being secure and available whenever you need them.
Featuring a 4th generation MEX Controller, the 850 PRO offers one of the most energy-efficient drives on the market, using up to 50% less power than traditional hard drives. It has the lowest active write power consumption and supports device sleep mode, which lowers power consumption to under 2mW.
  • 2.5" SATA III Solid State Drive
  • 256GB
  • SEQUENTIAL READ SPEED: Up to 550MB/s
  • SEQUENTIAL WRITE SPEED: Up to 470 MB/s
Product Description Samsung 850 PRO MZ-7KE256BW - solid state drive - 256 GB - SATA 6Gb/s
Type Solid state drive - internal - Hardware Full Disk Encryption (FDE), TRIM support, Automatic Garbage Collection, DevSleep mode, Samsung 3-core MEX Controller, Microsoft eDrive compatible, 3D V-NAND Technology, Dynamic Thermal Guard protection, RAPID mode support, Low Power DDR2 SDRAM Cache
Capacity 256 GB
Hardware Encryption Yes
NAND Flash Memory Type Multi-level cell (MLC)
Form Factor 2.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Buffer Size 512 MB
Features Hardware Full Disk Encryption (FDE), TRIM support, Automatic Garbage Collection, DevSleep mode, Samsung 3-core MEX Controller, Microsoft eDrive compatible, 3D V-NAND Technology, Dynamic Thermal Guard protection, RAPID mode support, Low Power DDR2 SDRAM Cache, S.M.A.R.T., 256-bit AES, IEEE 1667
Dimensions (WxDxH) 69.85 mm x 100 mm x 6.86 mm
Manufacturer Warranty 10 years warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung 256GB 850 Pro...
