The Samsung 850 PRO SSD redefines storage with the world's first drive based on 3D VNAND flash, offering exceptional read/write performance, reliability and power management efficiency. The 850 Pro delivers up to 2x the speed, density and endurance of conventional flash.
Ultimate Read/Write Performance
Samsung's 850 PRO, the world's first 32 layer 3D V-NAND, provides up to 100K IOPS Random Read Speed and 470 MB/s Sequential Write speed and the option of enabling Samsung RAPID mode, which can kick up to even higher speeds. With up to 2x the speed and density of conventional 2D flash, you get the most speed available for gaming and real world performance
Enhanced Endurance and Reliability
With an industry-leading 10 year, 150 TBW warranty, the 850 PRO offers unbeatable reliability. When combined with the 850 PRO's 256-bit AES Self-Encrypting Drive (SED) security technology, you can rely on your files being secure and available whenever you need them.
Efficient Power Management
Featuring a 4th generation MEX Controller, the 850 PRO offers one of the most energy-efficient drives on the market, using up to 50% less power than traditional hard drives. It has the lowest active write power consumption and supports device sleep mode, which lowers power consumption to under 2mW.
Product Description | Samsung 850 PRO MZ-7KE256BW - solid state drive - 256 GB - SATA 6Gb/s | Type | Solid state drive - internal - Hardware Full Disk Encryption (FDE), TRIM support, Automatic Garbage Collection, DevSleep mode, Samsung 3-core MEX Controller, Microsoft eDrive compatible, 3D V-NAND Technology, Dynamic Thermal Guard protection, RAPID mode support, Low Power DDR2 SDRAM Cache | Capacity | 256 GB | Hardware Encryption | Yes | NAND Flash Memory Type | Multi-level cell (MLC) | Form Factor | 2.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 512 MB | Features | Hardware Full Disk Encryption (FDE), TRIM support, Automatic Garbage Collection, DevSleep mode, Samsung 3-core MEX Controller, Microsoft eDrive compatible, 3D V-NAND Technology, Dynamic Thermal Guard protection, RAPID mode support, Low Power DDR2 SDRAM Cache, S.M.A.R.T., 256-bit AES, IEEE 1667 | Dimensions (WxDxH) | 69.85 mm x 100 mm x 6.86 mm | Manufacturer Warranty | 10 years warranty |
General | |
Device Type | Solid state drive - internal |
Capacity | 256 GB |
Width | 69.85 mm |
Depth | 100 mm |
Height | 6.86 mm |
Performance | |
SSD Endurance | 150 TB |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 550 MBps (read) / 520 MBps (write) |
Maximum 4KB Random Write | 90000 IOPS |
Reliability | |
MTBF | 2,000,000 hours |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s - 7 pin Serial ATA |
Compatible Bay | 2.5" |
Power | |
Power Consumption | 3.5 Watt (active) , 50 mW (idle) , 2 mW (sleep) |
Software & System Requirements | |
Software Included | Drivers & Utilities, Samsung Magician Software, Samsung Smart Migration Software, Samsung Drive Manager |
Manufacturer Warranty | |
Service & Support | Limited warranty - 10 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
Shock Tolerance | 1500 g @ 0.5ms half-sine pulse |
Shock Tolerance (non-operating) | 1500 g @ 0.5 ms |
Vibration Tolerance (non-operating) | 20 g @ 20-2000 Hz |
