A modern take on a classic. The next generation Bar Plus elevates the flash drive to an everyday essential, offering impressive speed and striking design. Fit to your hand, the metal unibody is pure minimalism in a drive that cleverly blends style, speed, and reliability.
Get your time back. Fast and convenient read speeds up to 300 MB/s with the USB 3.1 standard give you more time to work, play, watch, and create. Send a 3GB 4K UHD video file from your Bar Plus to your PC in just 10 seconds.
Product Description | Samsung BAR Plus MUF-256BE4 - USB flash drive - 256 GB | Product Type | USB flash drive | Interface Type | USB 3.1 Gen 1 | Storage Capacity | 256 GB | Enclosure Colour | Titan grey | Manufacturer Warranty | 5-year warranty |
General | |
Compatibility | Non-specific |
Memory | |
Read Rate | Up to 300 MB/s |
Features | Shockproof, magnetic-proof, waterproof, X-ray-proof, temperature-proof, metal body, key ring loop |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Dimensions & Weight | |
Width | 15.46 mm |
Depth | 12 mm |
Height | 40 mm |
Weight | 11.5 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
