The curvature of Samsung CF591 provides a truly immersive viewing experience that lets you enjoy big, bold and stunning panoramic views while you work or play. With its design inspired by the curve of the human eye, the Samsung CF591 monitor delivers a comfortable and enjoyable viewing experience for your home or office use. It boasts sleek curves and a stylish design that will compliment any room. Experience vibrant, stunningly vivid colors with Samsung's Active Crystal Color technology. The excellent 3000:1 contrast ratio delivers deeper blacks and brighter whites so you can clearly see even in an extremely dark or bright scene.
Product Description | Samsung C27F591FDU - CF591 Series - LED monitor - curved - Full HD (1080p) - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class B | Energy Consumption per Year | 54 kWh | Power Consumption (On mode) | 37 W | Curved Screen | Yes | Adaptive-Sync Technology | AMD FreeSync | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.3113 mm | Brightness | 250 cd/m² | Response Time | 4 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Tilt | Colour | White silver | Dimensions (WxDxH) - with stand | 61.42 cm x 27.04 cm x 45.73 cm | Weight | 4.4 kg | Compliant Standards | DDC-2B, ISO 9241-307 | Manufacturer Warranty | 2-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Curved Screen | Yes (1800R) |
Panel Type | VA |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | MagicBright, game mode, Eco Saving, Mega Infinity Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Mercury free, Eye Saver Mode, Active Crystal Color |
Dimensions (WxDxH) | 61.42 cm x 27.04 cm x 45.73 cm - with stand |
Weight | 4.4 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 5 Watt |
Connectivity | |
Interfaces | VGA , HDMI , DisplayPort , Audio line-in , Headphones |
Mechanical | |
Miscellaneous | |
Cables Included | 1 x HDMI cable |
Power | |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Software / System Requirements | |
OS Required | Apple MacOS, Windows 10 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 61.42 cm - depth: 27.04 cm - height: 45.73 cm - weight: 4.4 kg , Without stand - width: 61.42 cm - depth: 14.29 cm - height: 36.29 cm |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
