165Hz refresh rate Conquer every enemy, even at soaring speeds. 165Hz refresh rate eliminates lag and motion blur for exhilarating gameplay with ultra-smooth action.
1ms response time (MPRT) Make every move count with a 1ms response time. Screen pixels change colours with near instant response, enabling fast-paced action to flow with real-world accuracy.
AMD FreeSync Premium Effortlessly smooth gameplay. AMD FreeSync Premium features adaptive sync technology which reduces screen tearing, stutter, and input latency.
Ergonomic design Reach the height of winning. Swivel, tilt, and adjust your monitor until all enemies are in perfect view. Your display can be moved freely so you can find total gaming comfort.
3-sided Borderless design Your legacy has no boundaries. The 3-sided borderless design unveils maximum space for bigger, bolder gameplay. Line up two displays precisely in a dual-monitor setup, so no enemies slip through the crack.
Product Description | Samsung Odyssey G3 S27AG320NU - LED monitor - Full HD (1080p) - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class E | Energy Consumption per Year | 28 kWh | Adaptive-Sync Technology | AMD FreeSync Premium | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 165 Hz | Brightness | 250 cd/m² | Contrast Ratio | 3000:1 | Response Time | 1 ms (MPRT) | Gaming | Yes | Colour Support | 16.7 million colours | Colour Gamut | 72% NTSC | Input Connectors | HDMI, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 100-240 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 61.82 cm x 23.42 cm x 52.06 cm | Weight | 4.8 kg | Manufacturer Warranty | 2-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Panel Type | VA |
Gaming | Yes |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Game mode, Mega Dynamic Contrast Ratio, Black eQualizer, Flicker Free technology, Eco Saving Plus, Eye Saver Mode, Off Timer Plus, Refresh Rate Optimizer, 3 Side Borderless Design |
Colour | Black |
Dimensions (WxDxH) | 61.82 cm x 23.42 cm x 52.06 cm - with stand |
Weight | 4.8 kg |
Connectivity | |
Interfaces | HDMI , DisplayPort 1.2 , Headphones |
Mechanical | |
Tilt Angle | -5/+20 |
Swivel Angle | 30 |
Rotation Angle | -2/+92 |
Height Adjustment | 120 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x DisplayPort cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 100-240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 19 kWh/1000h |
Power Consumption (Typical) | 19 Watt |
Power Consumption (Max) | 35 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 61.82 cm - depth: 23.42 cm - height: 52.06 cm - weight: 4.8 kg , Without stand - width: 61.82 cm - depth: 9.24 cm - height: 37.69 cm - weight: 3.3 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 70.4 cm |
Shipping Depth | 46.4 cm |
Shipping Height | 21.8 cm |
Shipping Weight | 7.2 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
