Experience the Quantum dot Curved Monitor
Ultimate Curve. Incredible Colour Expression.
Lifelike Colour. Redefined with Quantum dot.
Samsung’s advanced Quantum Dot display delivers richer, more vivid colours bringing movies, sports broadcasts live-streamed gaming and more to life. Multi-coated semiconductor particles ensure long-lasting image quality while Samsung’s unique cadmium-free technology is harmless to the environment.
More Detail, More Space
WQHD Resolution
With up to 1.7 times the pixel density of Full HD, WQHD not only delivers incredibly detailed, pin-sharp images — it also creates a wider workspace that lets you view more of documents and webpages onscreen with less need to scroll or zoom.
Total Immersion
1800 Curvature
Designed to wrap around your field of vision and draw you deeper into onscreen movie and gaming action, Samsung’s industry-leading 1800R curved screen delivers a truly immersive viewing experience.
Curved for Comfort
A clinical study by Harvard Medical School showed that, when performing nearly one hour of intensive visual tasks, fewer users reported eyestrain and blurred vision with a curved monitor than with a similar widescreen flat monitor.
Eye Saver Mode
By minimising blue light emissions that cause eyestrain, Eye Saver Mode alleviates eye fatigue and provides a more comfortable viewing experience.
Flicker Free
Samsung’s flicker-free technology minimises distracting screen flicker to let you work and play for longer in greater comfort.
360° design
The CH711 curbed monitor cleverly conceals cables in its rear panel and stand for a stylish look from all sides, while the 3-sided bezeless display enhances its slender profile and offers a seamless viewing experience.
Smoother Gaming with AMD FreeSync
With AMD FreeSync technology you’ll enjoy flawlessly smooth gameplay in any kind of action. And Game Mode lets you effortlessly select screen settings optimized for different game genres to ensure you see darker areas in more the detail in game scenes.
Deeper Blacks
3000:1 Contrast ratio
Samsung’s advanced VA panel technology minimizes light leakage across the entire screen, even at the corners, and delivers a 3000:1 contrast ratio for deeper blacks and more brilliant whites in the very darkest and brightest of scenes.
Product Description | Samsung C27H711QEU - CH71 Series - QLED monitor - curved - 27" | Device Type | QLED monitor - 27" | Energy Class | Class C | Energy Consumption per Year | 77 kWh | Power Consumption (On mode) | 53 W | Curved Screen | Yes | Adaptive-Sync Technology | AMD FreeSync | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | WQHD 2560 x 1440 at 60 Hz | Pixel Pitch | 0.2335 mm | Brightness | 300 cd/m² | Contrast Ratio | 3000:1 | Response Time | 4 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, Mini DisplayPort | Display Position Adjustments | Tilt | Colour | White | Dimensions (WxDxH) - with stand | 61.42 cm x 27.63 cm x 46.2 cm | Weight | 5.3 kg | Compliant Standards | ISO 9241-307, EMI | Manufacturer Warranty | 2-year warranty |
General | |
Display Type | QLED monitor / TFT active matrix |
Diagonal Size | 27" |
Viewable Size | 26.9" |
Curved Screen | Yes (1800R) |
Panel Type | VA |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | MagicBright, game mode, Mega Contrast, Magic Upscale, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode, FreeSync Technology, Quantum Dot Technology, 125% sRGB colour gamut |
Colour | White |
Dimensions (WxDxH) | 61.42 cm x 27.63 cm x 46.2 cm - with stand |
Weight | 5.3 kg |
Connectivity | |
Interfaces | HDMI , Mini DisplayPort |
Mechanical | |
Tilt Angle | -2/+15 |
Miscellaneous | |
Cables Included | 1 x HDMI cable |
Power | |
Voltage Required | AC 120/230 V |
Power Consumption Operational | 48 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 61.42 cm - depth: 27.63 cm - height: 46.2 cm - weight: 5.3 kg , Without stand - width: 61.42 cm - depth: 6.5 cm - height: 36.2 cm - weight: 3.8 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years - on-site |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
