Samsung 2TB Portable SSD X5 Thunderbolt 3
£899.73
Select:
Delivery:
Standard: 1-3 working days
Key features
  • Wield the power of Thunderbolt 3
  • Built to be cool and durable
  • Form Factor: 2.5"
  • Capacity: 2TB, 2TB
  • Interface: Thunderbolt 3
  • Type: External hard drive
  • Stock Status: In Stock, Used Stock
Product codes
Samsung Portable SSD X5
Professionalism at its finest
Elevate your storage tasks to ultimate heights on PCs and Macs with Thunderboltâ„¢ 3 ports. The X5 is designed for tech savvy professionals who want to render or compile high resolution contents faster than ever. Its thermal management and password protection offer both comfort and security.
Wield the power of Thunderboltâ„¢ 3
Thunderbolt 3 and NVMe Interface
The X5 is here to quench your thirst for advanced technology. Thunderbolt 3 delivers the fastest bandwidth up to 40 Gb/s that brings lightning speed and performance. Equipped with the astonishing speed of NVMe interface, the X5 assists with handling heavier data at faster speeds.
Product Description Samsung X5 Portable MU-PB2T0B - solid state drive - 2 TB - Thunderbolt 3
Type Solid state drive - external (portable) - Dynamic Thermal Guard protection, NVM Express (NVMe)
Capacity 2 TB
Hardware Encryption Yes
Encryption Algorithm 256-bit AES
Interface Thunderbolt 3 - USB-C
Data Transfer Rate 40 Gbps (Thunderbolt 3)
Features Dynamic Thermal Guard protection, NVM Express (NVMe), 256-bit AES
Power Source Thunderbolt bus
Enclosure Colour Grey
Dimensions (WxDxH) 11.9 cm x 1.97 cm x 6.2 cm
Weight 150 g
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used but is in excellent condition
Ref: DRP5 040765
£409.74
product
Ref: DRP5 040765
Accessories
Packaging
Functional
Software
Manuals
£409.74
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung 2TB Portable S...
£899.73
