We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
165 Hz refresh rate 1 ms response time makes it perfect for crisp and smooth gameplay
Curved Quad HD display offers a lot of detail and fills your field of view much better than a flat display would, making for immersive gaming and viewing
AMD Freesync Premium technology takes care of screen tearing, blurring and other artefacts for smooth action in games, even if your framerate dips lower now and then
VA screen with HDR10 support boasts sharp contrast, deep blacks and wide viewing angles, so it even looks great from the side
Product Description | Samsung Odyssey G5 S32AG550EU - LED monitor - curved - 32" - HDR | Device Type | LED-backlit LCD monitor - 32" | Energy Class | Class G | Energy Consumption per Year | 57 kWh | Curved Screen | Yes | Adaptive-Sync Technology | AMD FreeSync Premium | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | WQHD 2560 x 1440 at 165 Hz | Brightness | 300 cd/m² | Contrast Ratio | 2500:1 | HDR Capable | HDR10 | Response Time | 1 ms (MPRT) | Gaming | Yes | Colour Support | 16.7 million colours | Input Connectors | HDMI, DisplayPort | Display Position Adjustments | Tilt | Voltage | AC 100-240 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 71.01 cm x 27.26 cm x 53.36 cm | Weight | 5.7 kg | Manufacturer Warranty | 2-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 32" |
Curved Screen | Yes (1000R) |
Panel Type | VA |
HDR Format | HDR10 |
Gaming | Yes |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Cinema Mode, Black eQualizer, CustomColor Mode, FPS Mode, Mega Infinity Dynamic Contrast Ratio, Flicker Free technology, RTS Mode, Eye Saver Mode, Off Timer Plus, Low Input Lag, Super Arena Gaming UX, borderless, Screen Size Optimizer, Refresh Rate Optimizer, RPG Mode, AOS Mode, Dynamic Contrast Mode, Auto Source Switch |
Colour | Black |
Dimensions (WxDxH) | 71.01 cm x 27.26 cm x 53.36 cm - with stand |
Weight | 5.7 kg |
Connectivity | |
Interfaces | DisplayPort 1.4 , HDMI , Headphones |
Mechanical | |
Tilt Angle | -2/+18 |
VESA Mounting Interface | 75 x 75 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x DisplayPort cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 100-240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 39 kWh/1000h |
Power Consumption HDR (On mode) | 66 kWh/1000h |
Power Consumption (Typical) | 39 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 71.01 cm - depth: 27.26 cm - height: 53.36 cm - weight: 5.7 kg , Without stand - width: 71.01 cm - depth: 13.59 cm - height: 43.94 cm - weight: 5.3 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 79.4 cm |
Shipping Depth | 20 cm |
Shipping Height | 49.4 cm |
Shipping Weight | 8 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
