We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Marketing description is not available.
Product Description | Samsung S32BM500EU - M50B Series - LED monitor - Full HD (1080p) - 32" - HDR | Device Type | LED-backlit LCD monitor - 32" - Smart monitor | Energy Class | Class F | Energy Consumption per Year | 49 kWh | Features | USB Hub, Wi-Fi, Bluetooth 4.2 adapter | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Brightness | 250 cd/m² | Contrast Ratio | 3000:1 | HDR Capable | HDR10 | Response Time | 4 ms (grey-to-grey) | Colour Support | 1 billion colours | Input Connectors | 2xHDMI | Display Position Adjustments | Tilt | Voltage | AC 100-240 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 71.61 cm x 19.35 cm x 51.7 cm | Weight | 6.2 kg | Compliant Standards | CEC | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix - Smart monitor |
Energy Class (HDR) | Class G |
Diagonal Size | 32" |
Built-in Devices | USB Hub, Wi-Fi, Bluetooth 4.2 adapter |
Panel Type | VA |
HDR Format | HDR10 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
OSD Languages | Multilingual |
Features | Game mode, ConnectShare, Flicker Free technology, Eye Saver Mode, DLNA, Auto Source Switch+, Adaptive Picture, Ultrawide Game View, Tizen Platform, Tap View, Remote Access, Sound Mirroring, SmartThings App Support, Adaptive Sound, Game Bar 2.0 |
Colour | Black |
Dimensions (WxDxH) | 71.61 cm x 19.35 cm x 51.7 cm - with stand |
Weight | 6.2 kg |
Audio | |
Type | Speakers |
Connectivity | |
Interfaces | 2 x HDMI , 2 x USB |
Mechanical | |
Tilt Angle | -2/+22 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), screen mirroring, Samsung DeX, Bixby Voice Assistant, AirPlay 2 |
Included Accessories | Remote control |
Cables Included | 1 x HDMI cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 100-240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 27 kWh/1000h |
Power Consumption HDR (On mode) | 39 kWh/1000h |
Power Consumption (Typical) | 27 Watt |
Power Consumption (Max) | 50 Watt |
Power Consumption Stand by | 0.5 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 71.61 cm - depth: 19.35 cm - height: 51.7 cm - weight: 6.2 kg , Without stand - width: 71.61 cm - depth: 4.18 cm - height: 42.45 cm - weight: 5.1 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 84.2 cm |
Shipping Depth | 13.3 cm |
Shipping Height | 48.7 cm |
Shipping Weight | 8.1 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
