We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The compact way to add big space. Plug in the FIT Plus to get secondary, upgraded storage for your devices, then leave it in to easily carry more files wherever you go. It stays out of your way and is so quick it keeps files at the ready, all with USB 3.1 speeds and trusted reliability.
Product Description | Samsung FIT Plus MUF-32AB - USB flash drive - 32 GB | Product Type | USB flash drive | Interface Type | USB 3.1 | Storage Capacity | 32 GB | Manufacturer Warranty | 5-year warranty |
General | |
Memory | |
Read Rate | Up to 200 MB/s |
Features | Shockproof, magnetic-proof, waterproof, X-ray-proof, temperature-proof |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Dimensions & Weight | |
Width | 23.6 mm |
Depth | 7.3 mm |
Height | 18.8 mm |
Weight | 3.1 g |
Environmental Parameters | |
Min Operating Temperature | -25 °C |
Max Operating Temperature | 85 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
